Disappointing Dyno results
Old Apr 25, 2012 | 03:41 PM
1powdercoater's Avatar
1powdercoater
Default ecs
Glad to hear your happy with the results from our mail order tune!
Thanks!!
Np, BTW Doug owes me a phone call. I know you guys are busy so if you could give me a email addy I'll send my question Thanks again.
Old Apr 25, 2012 | 09:03 PM
vet4me's Avatar
vet4me
Originally Posted by KCvetteowner
Don't take this personally because there are a lot of people on forums who post only their max hp values and ask why didn't they gain more??
Here are some things you should consider when looking at the ENTIRE dyno graph.
1) You could have gained 15 hp from 2k-3k rpm but since it's not the maximum HP/TQ you just ignored it.
2) You don't mention TQ how much TQ did you gain?
3) What does your Air/Fuel ratio look like along your dyno graph?
Can you post the before and after graphs???
The TQ gain was the same as the hp.Air/fuel was around 13.I'll see if i can figure out how to post the graphs
Old Apr 25, 2012 | 09:07 PM
vet4me's Avatar
vet4me
Originally Posted by bikerjim2000
stock c5 muffs? Time for some ZO6 ti's! And I think 01 was when the ls6 intake was used...
Already running Ti's
Old Apr 25, 2012 | 09:11 PM
vet4me's Avatar
vet4me
Final numbers were 331.85hp max tq 339.67.
Old Apr 25, 2012 | 09:26 PM
C5Natie's Avatar
C5Natie
Does anybody else see that it may be a bit much to ask for 15hp to the wheels by putting headers on a stock LS1? The motor isnt even utilizing the flow capabilities of the headers. On top of that the exhaust is still flowing through the restrictive stock mufflers. So 6rwhp+/- aint that bad for stocker with a cai. Maybe this is one of those situations where someone wants to add the advertised hp by bolting on a part. Remember that highly modded cars pick up 20-30hp avg with headers. Idk, jmo.
Old Apr 25, 2012 | 10:05 PM
ctusser's Avatar
ctusser
Yea, I argue this over on the C5Z section all the time.
Someone dynos stock at 355whp, puts on headers an air intake and gets a dyno tune and puts down 385whp, and says the headers were worth 30hp. Not true. With just an aftermarket air intake and a tune they usually put down in the low 370whp range, which is really only an increase of 10-15hp for the headers. This is on an ls6 where the flow demands are even higher than an LS1.
Old Apr 25, 2012 | 11:16 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Originally Posted by ggroller
Correct me if I'm wrong, but I don't believe the horsepower gains of a Vararam can be substantiated on a dyno. You need to be driving down the down with air flowing through it to notice the gains.
You are right, the VRB2 numbers will not show up on the dyno! You can get some idication if you place two barrel fans blowing directly into both sides of the grill openings.
Glenn, Bo,,,,crosswinds?
Old Apr 26, 2012 | 12:15 AM
retired cop's Avatar
retired cop
So a c5 picks up less than 10 hp when headers are installed??
Old Apr 26, 2012 | 12:28 AM
C5Natie's Avatar
C5Natie
We are talking a bone stock car. A stock engine just wont create enough exhaust pressure(combustion chamber pressure)to take full advantage of the flow and scavenging effect of headers. The more power an engine makes, the more air it takes in resulting in more exhaust gases to get out. Then it really benefits from headers. The stock exhaust system actually flows pretty decent compared to other cars manifold type setups. They almost look like little shorty headers, not bad for a little 347 making 345-350hp at the flywheel. I would consider headers once someone starts getting into heads/cam or forced induction type of mods. On a stock car it is very hard to justify the price vs gains.
Old Apr 26, 2012 | 01:41 AM
RonSSNova's Avatar
RonSSNova
In this very same Tech section, there are modified throttle bodies that claim 12-16 rwhp average.
Hmmmmm.
Ron
Old Apr 26, 2012 | 01:56 AM
C5Natie's Avatar
C5Natie
Lol, and those resistors that are supposed to connect to your IAT sensor that give 40rwhp.
Old Apr 26, 2012 | 03:51 AM
Vicarious.'s Avatar
Vicarious.
Hmmmmm.
Ron
They may, but only with the right supporting mods. It sure isn't going to add that kind of power on a stocker.
Old Apr 26, 2012 | 07:30 AM
  #33
vettenuts's Avatar
vettenuts
331 on a stock motor with headers is about the norm from what I have seen. One other factor to look at, what time of year was the first dyno and this one. Reason for asking is the fuel difference, i.e., winter blend has less BTU per gallon and will read lower on the dyno than the summer blend.
