Rear main seal
Old Apr 24, 2012 | 10:38 PM
Bobtam's Avatar
Bobtam
Default Rear main seal
Changing my clutch and noticed the cover plate that holds the rear main seal is leaking. I'm going to replace the gasket and seal while everthing is apart. What are the torque specs and is there a tightening sequence for the cover.
Old Apr 25, 2012 | 12:50 AM
Lothar34's Avatar
Lothar34
I think it's 18ft*lbs for the bolts into the block, and 109in*lbs for the bolts going into the cover from the pan. Go from the center out.
There are instructions here for the front cover (see the end of section 4) and the back cover is the same, don't forget the dab of RTV on the corners, just skip the part about the pulley:
http://www.ls1howto.com/index.php?article=1
Old Apr 25, 2012 | 01:44 AM
feeder82's Avatar
feeder82
You should use the J41479 tool for the rear seal, the alignment is critical, not an easy install without it
To Rear main seal
