2 different column lock bypass mods
Old Apr 25, 2012 | 03:54 AM
Silnus's Avatar
Silnus
Default 2 different column lock bypass mods
Im sure this has already been discussed but I found 2 different CLB's are for sale on ebay. When I did this to my other Z06, there was only the one for sale from corvettesofhouston. Now there is this one as well. Here is a link to both. Anyone have feedback on the LMC5 module?
LMC5 Module
http://www.ebay.com/itm/LMC5-MODULE-...079e5a&vxp=mtr
Corvettes of Houston CLB
http://www.ebay.com/itm/STEERING-WHE...a6171b&vxp=mtr
Old Apr 25, 2012 | 04:25 AM
65GGvert's Avatar
65GGvert
There's already tons of feedback on the forum about them. Here's one:
http://www.google.com/url?sa=t&rct=j...Vks5lhC9dY5QXA
And here's a longer one with more input:
http://forums.corvetteforum.com/c5-t...t=rid+pull+key
Old Apr 25, 2012 | 06:12 AM
SMaster's Avatar
SMaster
I installed a LMC5 in my buddies '03 yesterday in about 10 minutes. (I know, what took so long). I read the directions first plus I've had a C5 BCM out so I knew part of what I was doing.
It worked perfect and exactly as described. Before installation he was getting pull key for 10 sec. messages and Service Column Lock messages. I tuned out the 2mp shutoff last week.
Problem solved forever!
HTH
I'm going to add the following for someone in the future that may get stuck:
LMC5 CLB Service Column Lock Pull Key Evansville Indiana
I have an extra LMC5 in my desk drawer. I'm not selling it. It's for any of my forum or Evansville buddies that get stuck somewhere
and need one in this area. I'll install it and you'll pay me for the cost of the module. Might save someone a bunch of cash
and make me feel good to share what I've learned here!
Old Apr 25, 2012 | 09:03 AM
absolutscharf's Avatar
absolutscharf
AFAIK, both do the same: generate a "column is unlocked" signal to the BCM in response to a "unlock column" command to the motor.
CLB is a mechanical relay that goes in place of the steering wheel lock motor (driver's side dash). So, the signal path from the BCM still goes through the column lock motor relay (next to the BCM) and the column lock motor harness.
LMC5 is a solid-state relay that attaches immediately to the BCM (under the passenger footwell), bypassing not only the column lock motor but also the relay and harness. It supposedly also addresses some timing glitches with some BCMs that could still cause a CLB to fail.
From an engineering perspective, I think the LMC5 is the better solution, which is why I installed one in my car last week, after having been stranded for the third time AFTER the stealership did the recall (no problems ever before the recall was done). So far, works like a charm.
To 2 different column lock bypass mods
