Pushrod length driving me crazy!
Old Apr 26, 2012 | 09:19 PM
Russ K's Avatar
Russ K
Just checked Comp Cam's master lobe profile catalog, looks like you got the XER lobed camshaft.
It's going to be noisy.
Russ Kemp
Old Apr 26, 2012 | 10:57 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Originally Posted by Russ K
Does that cam use Comp Cam's XER lobes? Just tuned a 2010 Camaro that had a 227/243 113 .614/.624 LSR Comp Cam, Kooks headers/exhaust and a 102 Fast intake. There was no valve train noise at all. Also there was no low speed buck/surge at all. Quietest cam I've heard on a LS motor.
Now after talking to Comp Cams about the LSL lobes used in their LSR cams, I'm going to swap my G5X3 114 cam for the 227/235/ 113 .614/.621 LSR cam.
The tech said I probably won't loose much if any top end power over the G5X3 cam, and will gain low load/low RPM drive-ability. And will be quiet because the LSL lobes seat the valves slower.
Russ Kemp
Russ, are those lobes the same design as the EPS lobes that Geoff Skinner sells? I have one of his new cams and I don't have much valve train noise.
Old Apr 27, 2012 | 01:10 AM
Russ K's Avatar
Russ K
I think there was some discussion that his lobes were his own design. But I was very impressed with the LSR cam in the 2010 Camaro.
What is your combo & which cam did you use?
How is your low throttle/load @50 mph in 4th like?
Russ Kemp
Old Apr 27, 2012 | 09:35 AM
vettenuts's Avatar
vettenuts
Originally Posted by Nver2loud
I have no idea what kind of lobes it uses. I looked at the box to see if it said anything, but it just shows the specs. I checked their site and found nothing too.
There are two ways to check preload, either use the adjustable pushrod you have and measure zero lash at TDC firing stroke or use a dial indicator. Based on my testing, Shane's method, calculations, dial indicator and adjustable pushrod all give the same results within a tolerance. If you need to dial it in within a few thousandths, then use a dial indicator.
The key to measuring is to ensure you are at zero lash. If you aren't sure, you can verify with feeler gauges as you measure.
Old Apr 27, 2012 | 01:29 PM
printmanjackson
Russ Kemp
I got Parick Guerra to spec me a cam out and he told me to get it through Geoff. Patrick spec'd to use his new lobe design. It drives great in 4th at 50 mph.
I think it's @ 230/230 with a .600 lift at 112
Old Jun 16, 2012 | 04:47 AM
mxdave91's Avatar
mxdave91
i'm probably missing something here but isn't this backwards? how would you achive more bolt turns with a longer pushrod?
"For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter..."
Old Jun 16, 2012 | 02:21 PM
vettenuts's Avatar
vettenuts
Think of an extreme case as an illustration. You have a pushrod that requires lets say one turn to reach 22 lb-ft of torque on the bolt. The bolt tightening is from the point where the rocker is loose within the rocker stand until the rocker bottoms in the rocker stand and then to preload the bolt. Now increase the pushrod by 1/2". The rocker will sit much farther from the rocker stand and will require more turns to get it to bottom. As you turn the bolt the pushrod is depressing the lifter or developing preload. So as the pushrod length increase, so does the preload and vise versa requiring more turns on the bolt.
Old Jun 17, 2012 | 01:51 PM
MT0911's Avatar
MT0911
+1
Old Jun 17, 2012 | 05:36 PM
ZZ06's Avatar
ZZ06
you said stock heads.....228R is not a massive cam. i see you have pulled valve covers. did you find anything unusal? check for cracks, metal shavings, loose rockers, needle bearings etc. Can you post the sound? Man i know you dont have many miles on the setup but you might have a lifter going bad.
Old Jun 17, 2012 | 06:52 PM
Supercharged111's Avatar
Supercharged111
My old 5.0HO Ford is being the same way, got all the shims and longer pushrods to get preload within spec (.020-.060) and it's loud as hell with the stock HO cam (210/210 @ .050"). What I've come to wonder is if the lifters lived their lives at one preload for so many years, and you go putting in a new cam and whatnot ending up with preloads slightly different than before across the board, if the lifter doesn't like this? Seems unlikely in theory, but then again so do a lot of things.
Old Jun 18, 2012 | 01:54 AM
mxdave91's Avatar
mxdave91
Thank you sir for the explanation. I don't know why I couldn't picture that in my head but you've made it very clear. Thank you!
