Wheel Sticks Out
Old Apr 26, 2012 | 08:06 PM
DanielR's Avatar
DanielR
Default Wheel Sticks Out
Some information about the vehicle first, then the question.
Vehicle: 2000 FRC
Mileage: 67,000
Wheels: TSW Interlagos 18 x 9 front 19 x 10.5 rear purchased from DOCZ- 1st Rate Corvette Parts & Acc. with correct C5 offsets.
Tires: Nitto INVO 265/35/18 front 305/30/19 rear
Alignment: OEM specifications 2 months ago.
Suspension: PFADT coilovers (problem existed before installing the coilovers)
The problem I am having is that the front driver side wheel and tire stick out about .25" further than the passenger side. The passenger side is just a little past flush with the fender. I have triple checked the stamped wheel size on the wheel. I've tried swapping the front wheels side to side and the front driver side still sticks out further than the passenger side. All of the suspension bushings appear to be in good shape. I just installed the PFADT coilovers so I took a close look while I was in there.
Can anyone guide me toward other areas to check? See picture below. Thanks
Old Apr 26, 2012 | 08:43 PM
momo20's Avatar
momo20
is there a spacer on that side of the car? dumb question is the rotor setting 100% against the hub?
Old Apr 26, 2012 | 09:16 PM
Lothar34's Avatar
Lothar34
Do you have more spacers behind your upper A-arms on that side?
Old Apr 26, 2012 | 09:41 PM
98DC231's Avatar
98DC231
that is within the tolerances for UAW "looks about right" fit/finish standards.
Old Apr 26, 2012 | 11:21 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
mine is the same way. The body will not sit on the frame perfect. This is the reason you should not use the body to set frame height
Old Apr 27, 2012 | 01:16 AM
DanielR's Avatar
DanielR
No wheel spacer if that's what you are referring to. I thought about the rotor also. I thought maybe it had a defect and was made thicker in the area that contacts the hub, but have not tested this yet.
I'll know soon enough. I've got a big brake kit I'm about to install so I'll compare the OEM front rotors at that time.
Less actually. The upper A-arm on the driver side has one spacer on each of the four bolts.
The upper A-arm on the passenger side has from front to back two spacers on each of the two bolts closest to the front of the vehicle and one spacer on each of the two bolts toward the rear.
Looks like I may just have to accept it, huh?
Anyone ever try to correct the issue? It was not noticeable with the OEM wheels and tires because they are not as wide. So, I guess the factory would not have known it was that far off.
Thanks everyone for your help. Any additional information or ideas would be great.
Old Apr 27, 2012 | 06:00 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Are you the original owner? Perhaps the car was in a wreck.
Old Apr 27, 2012 | 07:48 AM
DanielR's Avatar
DanielR
It's possible and I thought about that, but I have not found any signs of it being in a wreck. The VIN stamps on the passenger side frame rail and crossbar are still intact, so I don't think it has been in anything too serious if at all. Carfax and Autocheck both came back clean when I purchased it, but that does not mean much. It was a two owner vehicle when I purchased it.
I figured if the problem was due to a wreck that a control arm or other suspension part would be visibly bent or damaged, correct?
To know for sure, I will probably have to have a good body shop look at it and see what they think.
Old Apr 27, 2012 | 08:13 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
I suspect that any of the damaged suspension components would have been replaced. As far as taking it to a body shop, it would have to be one with frame machine. I don't think it's worth the expense to have the frame measured. If you have access to a lift, you can take some crude measurements yourself, all of the frame dimensions are listed in the service manual.
Old Apr 27, 2012 | 09:28 AM
marvinseah's Avatar
marvinseah
My d/s rear sticks out about a 1/4" more than the p/s on my 04 Z06. FWIW
Old Apr 27, 2012 | 10:01 AM
AU N EGL's Avatar
AU N EGL
looks like time for an alignment again
Good Luck
Old Apr 27, 2012 | 10:53 AM
DanielR's Avatar
DanielR
Good Luck
Yes, I will need another alignment. I just installed the coilovers, so I'm driving it now to get it to settle so I can adjust and finialize the ride height before having it aligned again. I had the first alignment done to see if maybe a camber issue was causing the wheel to stick out, but no luck on that one.
Old Apr 27, 2012 | 11:42 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
If you really look hard at C5, and C6's you will be surprised how many have one wheel stick out more on one side than the other. My Drivers rear sticks out a pinch more than my passenger rear (<1/4"). Never been in an accident and I bought it brand new. A friend with a C6 has same issue but his rear passenger side sticks out (1/4")(he bought it new also). I have also personally seen 5 or 6 others locally with same issue. I did not tell them because I did not want them to worry about it. Its not just a C5 issue either... C6's have the issue too as I mentioned above.
Its mostly noticed on lowered cars. Once that wheel is closer to the fender that's when you notice it more. If its in stock 4x4 mode its harder to notice the issue.
I believe its a normal issue on our cars. More common than most want to believe. Maybe our car's body was set on the frame on a Monday, or a Friday...
Toque
Old Apr 27, 2012 | 11:52 AM
marvinseah's Avatar
marvinseah
Toque
True story! My wife's 04 Z06 is the same way. No big deal IMO!
Old Apr 27, 2012 | 12:48 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Toque
It is also common on the C4's. I had one ('94) that I hit a deer with and the front end was pushed off to the driver's side a little bit. Most would never notice, but since then, it stands out to me and I notice them.
I have seen it on a lot of C4's, C5's and C6's to some extent. I think there is just variation in the builds of these cars.
Old Apr 27, 2012 | 01:02 PM
DanielR's Avatar
DanielR
I have another vehicle (not a Corvette) that is hand built and the main difference between cars are in body panel gaps not so much the suspension or drive line. That is why I did not think this was an issue that is so widespread and originating from the factory.
I guess I'll just have to get used to it. The Corvette is fun and an 80% daily driver. I'll just accept it and enjoy the car.
Old Apr 27, 2012 | 01:26 PM
tlove32's Avatar
tlove32
Mine is the same way in the rear.....driver side sticks out a tad, but the passenger side sits flush. It is - what it is.....
To Wheel Sticks Out
Solofast's Avatar
Solofast
Yup, that's the way it was most likely built. Remember these plastic fenders are just hung on and stuck down with glue. No reason to make them perfect. Moreover, the frames on all these cars aren't square. That marvelous hydroformed tubing is all over the palce.
Very common when setting these cars up for the track to have to ream out the hole for the pin that locates the subframe relative to the frame so that you can get the same amount of negative camber on each side. My RF tire is closer to the fender than the left and I've rubbed the RF lip when running 295's with 1/4 inch spacers up front, and didn't get close to the LF lip..
That's just the way it is. You could move the subframe over to get it equal, and add shims to one side to get the alignment back.. Or you can just leave it.
Old Apr 27, 2012 | 02:01 PM
DanielR's Avatar
DanielR
Thanks for everyone's input. Successful thread! I was able to find others with the same/similar issue and find out what my options are to correct it if I ever choose to do so.
Thanks again!
Old Apr 27, 2012 | 02:36 PM
leadfoot4's Avatar
leadfoot4
All this discussion, so I had to go out to the garage and take a look at my car. It's an '01, I'm the original owner, it's never been hit. A lot depends on how you stand, when looking down the car, but I'd say my LR stick out about 1/8" more than the right, and the RF about 1/8" more than the left....
