line lock,install
Old Apr 27, 2012 | 09:57 AM
calvette 11's Avatar
calvette 11
Default line lock,install
Well I have completed two,c-3,c-4.
I help some help installing a line lock on my 2000 vette.I got a kit from summit,instructions not good.I need to know which lines I need to disconnect
Old Apr 27, 2012 | 12:24 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
The rear line on the master goes to the front wheels.
Old Apr 27, 2012 | 06:06 PM
calvette 11
Default line lock
How do you bleed the abs?After the install.
Old Apr 27, 2012 | 07:53 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
As long as you don't allow the master to empty, you should be able to use a suction bleeder on each wheel and pull the fluid through. The abs will not be affected.
At least, that's how I did mine and had no issues.
Old Apr 28, 2012 | 09:08 AM
Hauln1203's Avatar
Hauln1203
You can also bleed them the old fashion way, with a buddy in the car pump the brakes then hold them while you open the bleeder allowing the air to escape, repeat untill you have no air bubbles.
do each wheel and remember to keep checking the master cylinder to ensure you have plenty off brake fluid. I use a short piece of clear plastic tubing slip it over the bleeder and route it into a catch can then you can see the bubbles and also tell when the new clean fluid reaches the caliper. I just installed a RSD line loc you will love it what a blast..
Old Apr 28, 2012 | 09:25 AM
calvette 11
Default line lock
Thanks to all,I will do this on Monday.I want to be able to,clean my drag radicals off .My goal is mid 11.00 this year
Old May 1, 2012 | 10:57 AM
calvette 11
Default fitting
The fitting for the 93,will not fit the master cylinder.Does any body
Know the correct size?
Old May 1, 2012 | 10:59 AM
calvette 11
Default fitting
Do you know the correct size fitting for the master cylinder?
Old May 1, 2012 | 11:03 AM
bumble-z's Avatar
bumble-z
You said you have an 00.
Where does the 93 fitting come into play?
At any rate.
I would go to a good auto parts store, such as NAPA, etc.
Ask for them to pull the year MC that you are working on, off the shelf & have them find a fitting that would screw into it.
Good luck.
Old May 1, 2012 | 06:10 PM
calvette 11
Default line lock
I have a 93 and a 2000.Summit only make a installation kit for the c-4.I got the 93 done.The problem is the fitting in master cylinder on the 2000,is one size larger.The 93 uses a M10 adapter.I have gone to three napa stores here today.I would like for some one to tell me where did they get their fittings.I live in the Atlanta area.I think I need a M12 adapter
At any rate.
Good luck.
help help
Old Sep 10, 2021 | 08:52 PM
427troy's Avatar
427troy
Does it not mess up the ABS unit to hold the pressure on the front ?
Old Sep 11, 2021 | 09:54 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
No…
To line lock,install
