6 spd tranny clutch question
Old Apr 27, 2012 | 11:49 AM
T Evans's Avatar
T Evans
Default 6 spd tranny clutch question
Recently purchased 2000 C5 6 spd with 88k on the odo. The clutch doesn't slip but it doesn't engage until the top end of the pedal travel. Do I have a clutch that is wore out or getting ready to go out? If so, do you have to drop the torque tube when doing a clutch, psr plate and flywheel change out? Or does the clutch have an adjustment on it to allow it to engage back closer to the floor board?
Thanks in advance
Old Apr 27, 2012 | 12:54 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I would try bleeding the clutch fluid 1st to make sure there isn't any air in the system--before blaming the cltch
