Headlight Buckets?
Old Apr 27, 2012 | 12:21 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Default Headlight Buckets?
Greetings all, question on my 2001 Coupe. The right side headlight bucket does not seat down properly, and sticks up about a quarter inch. The drivers side seats flush! The bad side appears to offset towards the outside front corner seems to be getting bound up somewhere. Also, the manual ***** which are supposed to raise the buckets without power do not seem to work on either side. They tighten and loosen, but the housing never appears to want to move.
Anybody have any thoughts or know of a link to adjust it? Searches found lots of info on replacing the motor gear but not much adjusting or maintaining the buckets themselves.
TIA!
Old Apr 30, 2012 | 11:33 AM
ryrob's Avatar
ryrob
TIA!
Are you sure it's the actual bucket sitting up a quarter inch? Most of the time it is just the headlight door cover that gets mis-aligned (either up/down or left/right). There are adjustment screws on all four corners under the headlight cover that will lower or raise it. Have you tried this?
Old Apr 30, 2012 | 01:40 PM
Chicago1's Avatar
Chicago1
Looks like your stop insulator gave up the ghost. If you look you will see these yellow tabs(4 of them). The arm is metal and the insulator is plastic. After awhile the insulators get chewed up and the stop point gets jacked up so the light goes up 1/4 of a turn. I'm pretty sure that is your problem. As far as the headlights motor, sometimes you have to turn them several times before the lights go up or down. Try to guide the headlight up with one hand as you turn the know with the other, remember it may take several turns before it moves.
Old May 10, 2012 | 08:11 AM
chasboy's Avatar
chasboy
Oldtimer
Greetings all, question on my 2001 Coupe. The right side headlight bucket does not seat down properly, Searches found lots of info on replacing the motor gear but not much adjusting or maintaining the buckets themselves.
I have a sort of similar problem. After addressing a problem with the DR side headlight, the Pass. side, after acting normally refuses to go up until I rotate the manual **** to 'loosen'(?) it. The it works normally for awhile. Is there an adjustment or setting I should be looking at??
Thanks!!
Old May 10, 2012 | 09:24 AM
Chicago1's Avatar
Chicago1
Thanks!!
Is it making any noise?
Old May 10, 2012 | 09:35 AM
chasboy's Avatar
chasboy
Oldtimer
Not when it refuses to go up. No consistency other than the manual **** is tight in one direction, so turning the other way 'loosens' it.
Old May 10, 2012 | 09:47 AM
mcgilles's Avatar
mcgilles
Check the plastic insulators mentioned earlier. This is a typical symptom when they get worn out. Swap the ones on the back of the headlight mechanism with the ones on the motor stops. They contact in different spots and the motor stop ones wear out first. See if that makes any difference.
Old May 10, 2012 | 10:26 AM
Chicago1's Avatar
Chicago1
So it's not going up at all unless you do it manually?
Not saying your wrong but usually when it's the insulators you get the snake eyed look. But never hurts to check. The next bet if it doesn't come on at all is usually the headlight control module.
Old May 10, 2012 | 07:19 PM
chasboy's Avatar
chasboy
Oldtimer
seems that once I 'loosen' it, it works normally for several cycles. FWIW, it almost seems like it 'tightens itself' over a period of time and then it's too bound up to release.
The light comes on fine, even with the bucket closed
Old May 10, 2012 | 09:56 PM
lionelhutz's Avatar
lionelhutz
TIA!
Check the motor and lift arm as suggested and make sure it's hitting on the stops correctly. If it is, then you may need to remove the lid and adjust it until it sits in the right location. The cover comes off and then there is another bracket that holds the cover you can move around to adjust the location of the lid. The bracket also has screws on the top you turn up and down to adjust the height of the lid.
Thanks!!
It sounds like the gear is failing. Try removing the arm from the motor, rotating the motor 1/2 turn and then installing the arm again.
To Headlight Buckets?
