Finally asking for advise
Old May 7, 2012 | 03:20 PM
tiojames's Avatar
tiojames
Originally Posted by dougbfresh
What does this have to do with LOW COMPRESSION in 3 cylinders.
Rich fuel mixture washes oil off cylinder walls, causes rings to lose seal, ergo low compression reading.
Old May 7, 2012 | 04:09 PM
dougbfresh's Avatar
dougbfresh
He should be doing the compression test with the fuel system disabled anyway-fuel should have ZERO bearing on this test.
Old May 12, 2012 | 05:25 PM
MikeV's Avatar
MikeV
So what did you find?
Mike V
Old May 16, 2012 | 02:44 PM
MikeV's Avatar
MikeV
Find anything?
Old May 16, 2012 | 03:08 PM
tcouty87's Avatar
tcouty87
Cruising
Sorry guys been crazy busy with work. Looks like the octane booster fried the o2 sensors replaced those and my ltfts went from 25+ to 12+. Still a problem but it definetly needed o2s. Still has a hard time finding idle while coming uP to a stoP light. Also was only getting 13.0-1 volts while running no loads (ac, headlights etc). Cleaned te terminals and all grounds again and I'm getting 13.9 now.
Have a code fOr my hvac now that says short to ground drivers side actuator. NOt sure if that would drop it that much.
On full throttle it has full power and pulls smooth with good afr. Going rich at idle though. Vacuum is good at 18 inches. Checked tps and egr. All checks out.
Thinking of what to search next.
Old May 16, 2012 | 03:42 PM
dougbfresh's Avatar
dougbfresh
Still does NOT explain your low compression.
Old May 16, 2012 | 03:45 PM
tcouty87's Avatar
tcouty87
Cruising
That was from the overly rich mixture. Passenger side o2 sensor was worse than drivers side. Fuel wash in just 10 minutes of idle had the oil very thin and reeked of gas. Compression is bak up to 185 +- a few all around.
