Decals/Chrome
Old May 16, 2012 | 11:18 AM
Irish Whiskey's Avatar
Irish Whiskey
Default Decals/Chrome
need to get old decals off chrome wheels - easy/safe way to do it?
thanks
Old May 16, 2012 | 11:58 AM
Corvette_Ed's Avatar
Corvette_Ed
If they are just regular "stick-em-on" decals you can use a regular hair dryer on high setting to heat up the glue so you can peel them off. Follow this with a mild soap/water mixture, and using a soft cloth (that you can throw away after) gently rub the area to remove the leftover glue.
Old May 16, 2012 | 05:02 PM
Irish Whiskey
thanks, I try it
Old May 16, 2012 | 05:21 PM
Corvette_Ed
Originally Posted by Irish Whiskey
thanks, I try it
You're welcome. I forgot to mention the soap/water mixture should be made out of hot water as hot as you can stand it. It makes it easier to remove the glue as the hot water keeps it soft.
To Decals/Chrome
