F45 Delete Questions
Old May 3, 2012 | 04:42 PM
Baldfart's Avatar
Baldfart
Default F45 Delete Questions
I decided to go the Bilstein route on my 2002 F45 equipped convert. Two questions I have not found the answers to. Once I have the F45 option deleted from the BCM can I:
1) Remove the select ride switch from the console and replace the plate with one without the switch without any problems?
2) Remove those sensors that are connected to the control arms with the linkage? I assume these are for the F45.
Old May 3, 2012 | 05:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
1- YES
2- YES
3- ENJOY your new and improved handling!!!!!!!
Old May 3, 2012 | 07:47 PM
Baldfart's Avatar
Baldfart
Thanks Bill thumbs:
Old May 5, 2012 | 08:06 AM
thetitan's Avatar
thetitan
What is the correct process to remove the f45 option from the BCM?
Titan
Old May 5, 2012 | 10:30 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
- F45 deprogramming : http://forums.corvetteforum.com/c5-t...ng-f-45-a.html
Old May 5, 2012 | 11:02 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
don't forget to disconnect the connector in the driver side rear tub...then never, ever reconnect it!
To F45 Delete Questions
