high volume oil pump
Old May 3, 2012 | 05:30 PM
wesz0691's Avatar
wesz0691
Default high volume oil pump
Is a high volume oil pump really necessary with a cam only swap in a 02 z with 20k miles?
Old May 3, 2012 | 05:59 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When I did my heads and cam,, I opted for a melling pump/// Glad I did.
Old May 3, 2012 | 08:30 PM
REDZED2's Avatar
REDZED2
I talked to several big engine builders last summer when the time came to do my H/C/I. Katech even said it wasnt necessary. The stock Ls6 oil pump is very good out of the box. This is a bigger deal on 98-02 F body cars. To each his own though whatever you choose will be fine either way. Im a couple weeks away from getting mine fired up. cant wait!!
Old May 3, 2012 | 11:17 PM
wesz0691's Avatar
wesz0691
thanks for the replys, I think ill just stick with my factory one.
Old May 4, 2012 | 07:18 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
It is never a bad idea to improve upon the oiling system. Any "big" engine builder should have said that at the least. Is it needed? Probably not but when your adding a cam and rpms it would not hurt to do so... IT wouldnt be the first time an OEM oil pump failed. Is it gauranteed to happen? no. Its an insurance factor
Old May 4, 2012 | 01:32 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I view it as one of those "While I'm in there" items. You're already 90% of the way there, right? IMHO- spend the $125 and replace it...
Old May 4, 2012 | 01:40 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
FWIW my girlfriends cam only car died a horrible death due to oil starvation...the oil flows front to back and up to the sensor then across the top...you see good pressure at the sensor and then..???? replacing cam bearings, cam etc is $$$$ get a Katech pump or go for teh Melling ...I got the Melling this go round...I see 80PSI at start up
Old May 4, 2012 | 11:48 PM
Paul 75 L82's Avatar
Paul 75 L82
Ported LS6 pump from Texas Speed.
Old May 4, 2012 | 11:54 PM
99blancoss's Avatar
099blancoss
Former Vendor
ported oem pumps do not move more oil and are still and oem pump. The flashing is cleaned up on them is all.
To high volume oil pump
