Code 1214 H C
Old May 4, 2012 | 04:12 PM
kuzmfly1's Avatar
kuzmfly1
Default Code 1214 H C
Hello after almost being run off highway I ran onto the shoulder and hit the wake up dummy grooves and my abs/ traction control lights came on. I treid to reset the code 1214 and it would not reset. About 7 months ago I did abs fixer diy from forum all was good until this happen any suggestions before I take it apart again. Thanks
Old May 4, 2012 | 04:14 PM
chaase's Avatar
chaase
St. Jude Donor '12
Double check the grounds first, otherwise open her back up.
Old May 4, 2012 | 08:44 PM
Trash's Avatar
Trash
The bumps may have jarred some of the solder joints in the ABS box. May have to open it up and look at them again.
Old May 5, 2012 | 12:10 AM
Chicago1's Avatar
Chicago1
Old May 5, 2012 | 03:13 PM
kuzmfly1's Avatar
kuzmfly1
Thanks for replies opened it up and resolderd 5 points had two of the i geuss there called valve tube where loose pushed back in. put back in and now i'm getting codes 1272 and 1274
To Code 1214 H C
