Check engine light
Old May 7, 2012 | 08:38 AM
bontrager's Avatar
bontrager
Default Check engine light
I have been having engine problems ever since I added a ported throttle body. Check engine light would come on and the engine would go into a reduce power mode (2000 vert with 17,000 miles on the oddometer).
Fast forward: I went to a tuner last week and he identified the problem as a bad knock sensor so I had both replaced and he finished his "tune".
As I was leaving he commented that if the check engine light would come on again let him know.
How could this be ( and the check engine light has come on and then sometimes goes off) since both sensors were replaced and then a dyno tune was performed. Even with the check engine light coming on the engine does NOT now go into the reduced power mode.
Any ideas; thank you.
Old May 7, 2012 | 09:15 AM
dougbfresh's Avatar
dougbfresh
Pull the codes YOURSELF and post them here. Your a SENIOR MEMBER, you should know how to do this!
Old May 7, 2012 | 09:58 AM
lucky131969's Avatar
lucky131969
So after replacing your throttle body(with a ported version), you started having problems. .........and your tuner's diagnosis was the knock sensors? Perhaps this is a crazy idea.....but have you considered putting the original throttle body back on?
Old May 7, 2012 | 10:42 AM
dougbfresh's Avatar
dougbfresh
Since a ported TB is a waste of time anyway.
Old May 7, 2012 | 11:07 AM
bontrager's Avatar
bontrager
Well it was an exchange type deal. You get the new throttle body for a reduced price and you have to send your core back to them, so I no longer have it. Sorry that I went for it!!!!!!
With the labor, one trip to Chevy dealership to tell me that they did get a throttle body code ( however keep driving it and the PCM will adjust) and another $400.00 for a tune, this was a very expensive "mod".
Now this morning after my second drive the check engine light is now off including the 3rd start and drive.
I will attemp to pull codes later.
Thank you for the responses.
Old May 7, 2012 | 11:29 AM
lucky131969
Seems like the first time success rate with the ported throttle bodies is about 50%. Stock throttle bodies are in the parts section all the time. You might consider picking one up as a contingency. Also, I would have a serious talke with your tuner, about the parts/hours you were charged for the knock sensors.
Old May 8, 2012 | 03:36 PM
bontrager's Avatar
bontrager
OK pulled the codes as suggested; thank you!
All end in a "H". Did this twice.
Any further suggestions???
How do I clear these codes if "H" (history) means nothing.
Thank you.
Old May 9, 2012 | 07:10 AM
bontrager's Avatar
bontrager
OK, I cleared all of my history codes (found instructions) and drove this morning about 7 miles to my newest office (Paneras, a bread store) and the check engine light did NOT come on.
I will keep monitoring the situation.
That ported throttle body mod has cost me a total of about $1200.00 including the knock sensors, dyno tune and labor (including one trip to the dealership to determine why engine was going into reduced power mode, ($100.00) .
Terrible waste of money!
Hope to supercharge someday.
Old May 9, 2012 | 08:46 AM
baxsom's Avatar
baxsom
you dont need a tune with a ported throttle body and the ported one I got from bare essential racing worked perfectly no codes out of the box. I must be part of the lucky 50%. You should have pulled the codes yourself. Changing out the knock sensors takes 30 minutes in the driveway and a mail in tune would have cost you 150, not 400.
Old May 9, 2012 | 11:55 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Ported TB's i think are a good Mod --just people expect too much from it---HP is minimal about 3-5 RWHP but the throttle response is much quicker---With a potted TB the incomig air increases--The ECM has the ability to correct the AFR and "learn out' with about 50-75 miles of drivng---In order to throw a TB realted code for this mod would mean the AFR (fuel trim) correction is past apprx 20%--It should never be that farr off with only a ported TB---make sure there are NO vacuum leaks---no intake tract leaks-Did you re-oil the air filter (if you have a CAI) very common mistake will make the MAF go crazy-- and throw codes as well--
Old May 9, 2012 | 12:07 PM
bontrager's Avatar
bontrager
Originally Posted by tblu92
Ported TB's i think are a good Mod --just people expect too much from it---HP is minimal about 3-5 RWHP but the throttle response is much quicker---With a potted TB the incomig air increases--The ECM has the ability to correct the AFR and "learn out' with about 50-75 miles of drivng---In order to throw a TB realted code for this mod would mean the AFR (fuel trim) correction is past apprx 20%--It should never be that farr off with only a ported TB---make sure there are NO vacuum leaks---no intake tract leaks-Did you re-oil the air filter (if you have a CAI) very common mistake will make the MAG go crazy-- and throw codes as well--
No, I have never re-oiled my dual cone filter.
Should I; new filters have only 5,000 miles on them.
Thank you.
Old May 12, 2012 | 08:18 AM
bontrager's Avatar
bontrager
OK, the engine went into reduced engine power again this morning after a cold start and spirited acceleration.
Pulled codes after I restarted the engine and was able to drive another 5 miles with the check engine light on but no other problems.
Here are the two codes (only codes) both with an H at the end (I'm sure I cleared these before).
10 PCM 1514H
28 TCS C1278H
Please advise; thank you
Old May 12, 2012 | 12:57 PM
tblu92's Avatar
tblu92
What's making it go into "reduced power mode" or limp mode is the P1514 code
You can clear it temporarily by starting and stopping the engine 3 times---but it will come back
To clear it PERMANTLY you will need someone with a tuner like HP or EFILIVE to adjust the " ETC Predicted Airflow Table" This table monitors the airflow vs throttle position--And if the predicted airflow is beyond what a stock or mildly modded engine would produce it goes into reduced power mode---typically any car that has been cammed and that has LT's and maybe a better intake manifold will produce this code
In EFILIVE it's table C6101----Simply ADD 25-30% to the entire table and it will never happen again-----
Old May 13, 2012 | 10:16 AM
bontrager's Avatar
bontrager
Thank you!!!!!!!!!.
Will call my tuner tomorrow.
Old May 13, 2012 | 12:35 PM
dougbfresh's Avatar
dougbfresh
Is it really worth all this for a little percieved better throttle response?
Old May 13, 2012 | 03:35 PM
bontrager's Avatar
bontrager
No it isn't!
To Check engine light
