need a tech 2
Old May 8, 2012 | 08:22 PM
tom01ss's Avatar
0tom01ss
Former Vendor
Default need a tech 2
hey all who has a gm tech 2 in pa area near philly airport. i replaced bcm now i need to relearn ign key and vats. the key trick doesnt work . please call me 610 931 0540. need so help here
Old May 8, 2012 | 10:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you tried this procedure:
BCM/PCM RELEARN PROCEDURE
You will need to conduct the PCM/BCM relearn process. This matches their handshake ID's and allows them to talk to each other.
Do this before you worry about VATS issues:
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
The car should start and run with the new BCM. Good luck and report back on your progress.
Shirl
SD Racing Enterprises
Aguila, AZ
Coutersy of MrEracer
This will sync the PCM to the New BCM but all of your RPO options will not be retained. You will need a TECH II to program them into the new BCM.
Bill Curlee
