Greasing axles??
Old May 9, 2012 | 08:48 PM
rttmike's Avatar
rttmike
Default Greasing axles??
Is there a way to get grease into the rear axle boots (where the joint is) without destroying the boots? Has anybody done this?
Old May 9, 2012 | 08:49 PM
Lothar34's Avatar
Lothar34
What happened to the grease that was in there?
Old May 9, 2012 | 09:00 PM
rttmike's Avatar
rttmike
After a while the grease breaks down. That's why a lot of areas that require grease have fittings to replenish the grease. Nothing lasts forever.
Old May 9, 2012 | 10:36 PM
dlind4's Avatar
dlind4
If your talking about the halfshaft boots there are no grease fittings. The only time you grease them is if you need to replace a boot that has been ripped or torn. You can tell they are leaking if there slinging grease all over the place. Most people just replace the whole axle shaft. I have replaced boots on other vehicles and theres a lockring you need to remove to separate the shaft to get the old boot off. I don't know how easy it is to do it on a corvette but assume its the same in principle. Maybe some one thats done it on a vette can chime in.
Old May 9, 2012 | 11:08 PM
Lothar34's Avatar
Lothar34
^^ Mine was leaking a few months ago and I just replaced the halfshaft. It was only $60 or so and was way easier than trying to replace the boot - which requires disassembling the U-joint.
I guess you could loosen the boot and just squirt some grease in there if it makes you feel better. If there's a problem though, you're better off just replacing the unit.
To Greasing axles??
