Headlight question
Old May 9, 2012 | 09:23 PM
04MSZ06's Avatar
04MSZ06
Default Headlight question
I never noticed this before but I recently switched out my headlights from the fixed style and now I am back to the pop-ups. My question is, after I finished installing them, when I turn the headlights on, they come up about half way, pause for a second, then continued until they are fully popped up. Is this normal? I seem to remember when I bought the car that when I turn the headlights on, they pop up without any hesititation. I'm not hearing any grinding or other noises. What gives?
Old May 9, 2012 | 11:17 PM
mcgilles's Avatar
mcgilles
not sure what the problem is, but its definitely not normal. they should come up smoothly.
does it stop at the exact same point each time?
do both lights do it or just one?
I'd check the arms that move the lights and make sure they are unobstructed. its possible you have a bad spot in the gears also, but unlikely it would be both of them.
the only thing that I can think of that's common to both would be the headlight door control module. they do go bad but that's an odd symptom.
Old May 9, 2012 | 11:23 PM
04MSZ06's Avatar
04MSZ06
I just checked them 4 times. Every time they stop at the same spot, or what appears to be the same spot, and both headlights do it. I manually opened and closed each light and they operate smooth. Is there any special way to reinstalling the motors other than making sure the arms go into the motor slots accordingly?
Old May 9, 2012 | 11:43 PM
jrose7004's Avatar
jrose7004
Mine come right up with no hesitation.
Old May 10, 2012 | 01:56 AM
DeeGee's Avatar
DeeGee
They should come up smoothly.
This is the extract from the book for reinstalling the motors:
Position the headlamp motor/actuator to the headlamp assembly.
Install the pivot arm to the motor.
Place the pivot arm in the position noted prior to removal.
Loosely install the nut retaining the headlamp assembly pivot arm to the motor/actuator.
Install the headlamp motor/actuator bolts.
Tighten the headlamp motor/actuator mounting bolts to 7 N·m (62 lb in).
Tighten the headlamp motor/actuator to pivot arm nut to 6 N·m (53 lb in).
If they are turning smoothly it doesn't sound like there's a problem with the gears, particularly as both headlights are hesitataing at the same point.
It strikes me that it has to be a problem with how the pivot arms have been reinstalled. I've not done the job myself so I'm guessing but is it possible to put them on in the wrong way? Reversed on the motor shaft maybe? The book makes a point about reinstalling them in the same position as they were removed. There must be a reason for that.
Old May 10, 2012 | 01:11 PM
lionelhutz's Avatar
lionelhutz
The arm can be installed either way on the motor. Turning the arm 180 degrees on the motor shaft is an easy way to test or get the motor working again if the gear is just starting to fail. It might not work so good on a badly stripped gear though.
I would suspect the wiring or the headlight switch. Do any of the lights flicker when this pause occurs?
Old May 11, 2012 | 03:05 AM
DeeGee's Avatar
DeeGee
The reason I was suggesting mechanical is that both doors hesitate at the same time. If it was only one, then I'd agree, a wiring problem is likely. If both arms are installed 180 out, and by doing so, the mechanism hesitates, it would cause the symptoms that the OP is seeing.
This is the wiring diagram. The signal goes through independent circuits to each motor. To get both motors to hesitate at the same time would need a discontinuity somewhere upstream of the headlamp door control module. From the diagram, the motors are fused individually at the footwell fuse panel. It's also strange that it occurs at exactly the same point in the cycle. I just can't imagine a wiring fault being that predictable. I also can't see why the switch would be the problem as it only applies a voltage onto the circuit. It's more common to see total loss of functions when the switch fails.
Just guessing based on the symptoms which have been described. It's an unusual problem
Old May 11, 2012 | 12:00 PM
04MSZ06's Avatar
04MSZ06
I will start troubleshooting today. I do know that I manually raised each light about halfway before I bolted the mounting arms to the motors (not sure if that matters). Out of curiosity, is there a point at which the motor stops turning if you operate it manually?
Old May 11, 2012 | 11:38 PM
CactusCat's Avatar
CactusCat
Yes, you can manually raise or lower the lights and if you continue you will get to a point where you cannot turn the **** anymore. There are stops on the side of the motor that prevents it from going beyond a certain point and when you lower the light, it will also only go so far. You'll feel the **** tighten up when you reach these points.
Old May 13, 2012 | 11:34 PM
lionelhutz's Avatar
lionelhutz
That is not the complete diagram. Where are the wires that tell the module to put the lights up and down? The signal wires will be common for both motors.
The motors can rotate forever if the arm is removed. The arm can go on the shaft either direction. The motor has a worm gear on it and this drives a round gear with teeth all the way around it. There is a rubber insert in the gear to absorb shocks and the output shaft has ears that insert into the rubber to drive it.
I highly doubt the motors would both mechanically jamb at the same spot. Also, the control box senses the extra current when the motor is stopped and shuts off the power to it. So, if the motor was mechanically jambed to a stop it would have the power cut and not be powered again to full-open.
That's why I suspect an electrical issue is temporarily cutting the signal to raise the lights or momentarily telling them to drop and then raise again so they try to reverse just long enough to stop before continuing up.
Do you happen to have HID lights in this car?
Old May 15, 2012 | 01:27 PM
DeeGee's Avatar
DeeGee
I try to do some research before I post....
There are about 5 as you work down the system. I tried to post the relevant diagram.
It's at the T/S switch. I'll try to dig it out.
Old May 15, 2012 | 01:33 PM
DeeGee's Avatar
DeeGee
Default The Other Diagrams
Here's the flow:
Old May 15, 2012 | 03:23 PM
lionelhutz's Avatar
lionelhutz
Nice. I would suspect something to do with headlights on input or headlight off input to the control module on the second last schematic.
To Headlight question
