Clutch
Old May 12, 2012 | 07:27 PM
blackc5vert's Avatar
blackc5vert
Default Clutch
Hi all anybody know what this sound means I have 6speed and when letting clutch out it makes a winding noise does this mean I need knew clutch and anybody have idea how it cost to replace,everything works just a winding noise,doesn't stay once clutch is up it goes away its just for a second or two for the noise?
Old May 12, 2012 | 07:29 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well first of all where are you located so perhaps someone can direct you to a good repair facility...
cost....depends...shop our vendors...if you want stock parts GMPartshouse or Parts Taxi both sell the packages....my last swap I went with the LS7 setup in my blown 99...labor will be more than parts
Old May 12, 2012 | 07:32 PM
blackc5vert
Oh sorry I'm n Florida broward county,is the car supposed to make a little noise when clutch is let up,
Old May 12, 2012 | 07:44 PM
blackc5vert
Pewter99 what do I replace and is it a hydraulic
Old May 12, 2012 | 07:49 PM
Paul 75 L82's Avatar
Paul 75 L82
Call Zen at Gold Corvette in Ft. Lauderdale, 954-564-8388. Tell him Paul with the Blue Z06 from Palm Beach sent you. He did my clutch.
Old May 12, 2012 | 07:56 PM
blackc5vert
Paul u have idea how much it would cost
pewter99's Avatar
pewter99
Horsepower Sales is close to you I believe...
none of my clutches have ever made noise on release unless they were toast
Old May 12, 2012 | 07:59 PM
blackc5vert
Pewter99 the car drives fine shifts perfect with no problems and I don't drive it hard the sound is like loose aluminum kind of sound
Old May 12, 2012 | 08:03 PM
blackc5vert
Oh I just want to thank everybody on this forum for helping ��
Old May 12, 2012 | 09:33 PM
blackc5vert
Default Clutch
I feel kind of stupid it's not the clutch making noise its engine noise like when Rpm r to low and engine catching up boy I feel stupid
Old May 12, 2012 | 10:44 PM
johnson-rod's Avatar
johnson-rod
If it's a rattling sound when starting off from a stop it's normal. Something to do with the throw out bearing. Not a problem.
Old May 12, 2012 | 11:01 PM
blackc5vert
Thanks I feel better now that is what I was trying to describe
To Clutch
