Can MAF be installed backwards?
Old May 14, 2012 | 05:07 PM
bartsky's Avatar
bartsky
Default Can MAF be installed backwards?
Which way does the arrow on the MAF face? Towards the TB or the CAI?
Old May 14, 2012 | 05:11 PM
lucky131969's Avatar
lucky131969
The arrow indicates direction of air flow.
Old May 14, 2012 | 05:20 PM
bartsky's Avatar
bartsky
So towards the TB, as it is installed that way. I know, dumb question Lucky. I'm glad you replied. I'm trying to figure out why I'm getting rich codes, and stumble between 2-3k RPM's on 03 Z with 17k miles, Vararam, headers, hi-flow cats, and mail order tune? Any ideas Lucky? Is it getting too much air with the Vararam, and PCM compensating with too much fuel? Thanks for any help...
Old May 14, 2012 | 05:36 PM
lucky131969
Too much air would precipitate a lean code. A few things can cause a rich condition, with the tune being an obvious first. High fuel pressure, a restriction in the air intake(duct, filter, etc.), MAP sensor, fuel in the crankcase. If both banks are throwing codes, then you have to look for what effects both sides.
Old May 14, 2012 | 05:52 PM
bartsky's Avatar
bartsky
Yes it is throwing rich codes for both banks. I just changed the oil, and it had good fuel odor, but it seems they all smell like fuel when you change the oil? The mail order tune leans it a bit, so I'm told. I have my tuner coming to plug into it tomorrow I hope. He should change the MAF tables?
Old May 14, 2012 | 06:02 PM
lucky131969
My oil doesn't smell like fuel.....not even on my 65 L76.
Old May 14, 2012 | 06:04 PM
chaase's Avatar
chaase
St. Jude Donor '12
Oil should not smell like fuel.
Old May 14, 2012 | 06:06 PM
ZeeOSix's Avatar
ZeeOSix
Sounds like the tune is pretty rich if your oil smells like gas. Get it on a dyno with a wide band O2 reader and see where the real A/F is at.
Old May 14, 2012 | 06:12 PM
bartsky's Avatar
bartsky
So what would that indicate if it does?
Old May 14, 2012 | 06:44 PM
bartsky's Avatar
bartsky
I just went out, and smelled the oil. It smells like oil, I just changed it maybe 200 miles ago. My exhaust tips are not really black, or have soot on them. Wouldn't they if I was actually running rich. Could a faulty 02 sensor be causing the rich codes?
Old May 14, 2012 | 06:45 PM
ZeeOSix's Avatar
ZeeOSix
Not sure exactly what your question is specifically, but if the oil smells like fuel then the A/F ratio is too rich and raw fuel is getting blown past the rings and into the crankcase.
Old May 14, 2012 | 06:47 PM
ZeeOSix's Avatar
ZeeOSix
If the O2 sensors were that bad, there would probably be trouble-code(s) set.
I thought you said earlier that when you changed oil last time it did have lots of gas smell.
Old May 14, 2012 | 06:50 PM
bartsky's Avatar
bartsky
Thank you for explaining that....
I was told that the mail order tune actually leans it a bit. So how could I be getting rich codes? The car does stumble at RPM's between 2-3k, but when you get into it, the car runs perfectly, and idles perfect. I have not taken the air intake assembly apart, because it looks to be installed perfectly, as the PO was a sharp guy.
Old May 14, 2012 | 06:59 PM
bartsky's Avatar
bartsky
I thought it did smell of gas, but I guess I was wrong.
Old May 14, 2012 | 07:03 PM
bartsky's Avatar
bartsky
I still had the oil in the drain pan in my garage. I went out and smelled it, and it sure smells like gas to me.
Old May 14, 2012 | 09:24 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Arrow points towards the MAF and it can't be run backwards -
Thanks,Matt
Old May 14, 2012 | 09:55 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
also, you could have a faulty PCM...the dyno should verify the voltage reading ability.
Old May 15, 2012 | 11:53 PM
bartsky's Avatar
bartsky
http://forums.corvetteforum.com/c5-t...post1580824856
Old May 16, 2012 | 12:45 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
unplug the MAF and it will make PMC use the VE table and see if it's still rich.
if you have someone coming to tune it, he will find the problem I'm sure
To Can MAF be installed backwards?
