Air pressure in Differential?
Old May 20, 2012 | 12:08 PM
Mastertvtech's Avatar
Mastertvtech
Default Air pressure in Differential?
I just changed out my diff fluid Thursday and noticed a loud rush of air when I cracked open the drain plug.
I just noticed that I have some gear lube in my driveway and it is dripping from the sway bar. I will pick it up on the lift tomorrow but wonder if the air pressure build up is normal, and if maybe this is related to the leak? It was dry as a bone before I drained it......
EDIT: Search results show that press is normal....I will have to have a good look at the vent...
Old May 20, 2012 | 02:18 PM
Cybermind's Avatar
Cybermind
If diff fluid spews out of the vent, then it is usually an indication of an overfilled diff. You should bring the level down to about a quarter inch below the fill hole. I have also found recently that some gear lubes are more susceptible to blowing out of the vent after long hot drives than others. This may simply be related to their viscosity stability under extreme heat conditions and resistance to foaming.
Old May 20, 2012 | 02:52 PM
Mastertvtech
Thanks for the info. I just checked after a 40 minute drive and all is dry. Probably what you suggested is true.
Old May 20, 2012 | 02:53 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
I changed my diff lube recently and did not experience a pressure release. Besides what has been said above, you might wish to check for a restricted or damaged vent valve assembly, as per the service manual (my manual is for the 2001 model year).
Old May 20, 2012 | 03:01 PM
tiojames's Avatar
tiojames
Pressure build up in the case is due to a plugged up vent. Just over filling the diff will not cause it to retain pressure. This pressure will also force lube out around the seals.
Old May 20, 2012 | 04:28 PM
Mastertvtech
In my search here I found most threads regarding this state the pressure release heard when opening the plug is normal?
I just noticed a quarter sized drop of gear oil under the rear again...It is only happening once it cools down from a trip. I had no leak whatsoever before I replaced the fluid and filled just to the plug.
Old May 20, 2012 | 05:18 PM
Fast one's Avatar
Fast one
The differential operates with a vacuum so when you open the drain plug you are supposed to hear air entering the case when the fluid is cool.
Old May 21, 2012 | 10:12 AM
lionelhutz's Avatar
lionelhutz
The vent is a 1-way check valve that lets air out but not back in. So, if anything, the diff should be under a vacuum when cold.
Old May 21, 2012 | 10:41 AM
ALLEGRO's Avatar
ALLEGRO
To Air pressure in Differential?
