Yet another PTMS Problem
Old May 20, 2012 | 01:20 PM
Crusher's Avatar
Crusher
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
Default Yet another PTMS Problem
My RF tire reads 24 lbs when there is 30 lbs in the tire. I can get the car into reset learning mode but I can't even get the LF tire to reset (beep the horn). I'm even using the round magnet made to reset TPM's. I tried an even stronger magnet and still no luck. Any suggestions?
Old May 20, 2012 | 02:34 PM
Crusher's Avatar
Crusher
NCM Ambassador
Cruise-In V Veteran
Originally Posted by 8VETTE7
have you tried placing the magnet inside the barrel of the wheel above the actual TPMS?
If that doesn't work you can skip the LF wheel and go to the RF wheel to see if any of the TPM's will program. But if you do the RF will show in the DIC as the LF.
Yup, and I also tried the rf where I'm having the problem and no beep. Yes, I checked my horn, it does work.
Old May 20, 2012 | 07:15 PM
aerovette99's Avatar
aerovette99
Sounds to me like your battery in the tpms is about to die.
I just rebuilt all 4 of mine and no more bad readings.
The Old style TPMS 97-2000 were good for 9-11 years but not much more than that.
Old May 20, 2012 | 08:41 PM
Crusher's Avatar
Crusher
NCM Ambassador
Cruise-In V Veteran
Mine is an 2004
To Yet another PTMS Problem
