Climate Control Help
Old May 20, 2012 | 08:45 PM
JustCuz's Avatar
JustCuz
Default Climate Control Help
So my Climate Control fan mode stopped working.
Every thing else works fine just can't change it to only blow out of the vents or to the floor. Any idens?
Oh and I just had to put a new oil sending unit in about a week ago.
Is there some thing I could of unplugged?
Any help would be great.
Thanks,
-JC
Old May 20, 2012 | 08:48 PM
Lothar34's Avatar
Lothar34
If you removed the intake manifold to change the oil pressure sensor, then you probably left the HVAC vacuum line unplugged on the rear.
Old May 20, 2012 | 08:49 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
vacuum lines run back there near the oil pressure sending unit...
Old May 20, 2012 | 08:52 PM
JustCuz's Avatar
JustCuz
will have to look in to this. Is it just that little black line in the back of the manifold?
Old May 20, 2012 | 10:03 PM
BigGun's Avatar
BigGun
That's the one.
To Climate Control Help
