A4 Diff TT install
Old May 21, 2012 | 12:05 AM
RonSSNova's Avatar
RonSSNova
Default A4 Diff TT install (Photos)
Hey all,
I have been working on this car since Oct last year. Bought it in Aug, drove it for a couple of months then took apart a perfectly good running car.
Anyway, I bought a 3.42 3 rib diff to beef up, an A4 to have built and a 2004 TT in order to get the stronger unit. It all went together this weekend.
The diff got DTE shafts, C6 posi kit and DTE springs. Very simple to work on thanks to the article by "It's Go time". The TT is a 2004 unit from a buddy. And the trans was done by Performabuilt.
It is a little nerve wracking doing this on the floor, but with my brothers help we pulled it off with a floor jack, and a jack cradle made of 2x4's. Being a bit edgy, I only took a few photos. So I thought I'd share them.
Yank SS3600
Assembled Drivetrain
On the jack
On the jack
On the cradle
I also took the opportunity to clean and paint the rear frame section as it was rather gross from NJ salt.
BTW, my first Corvette.
Enjoy!
Ron
Old May 21, 2012 | 07:36 PM
gort69's Avatar
gort69
3rd Gear
DUDE rad gnar awesome work DUDE
Old May 21, 2012 | 10:33 PM
RonSSNova's Avatar
RonSSNova
Butthead.
Gort 69 is my brother. a 69 Camaro owner although it does have C4/C5/C6 brake setup on it.
Old May 22, 2012 | 01:32 AM
j5mm2's Avatar
j5mm2
Cruising
I have a 2003 a4, and wanted do a 3.42 reduction, did you rebuild your core housing, or purchase DTE's stage kits? Any advice on minimizing costs when purchasing/installing ring and pinion sets? I want minimum costs, but from what I can tell, I'm looking at 2400$ for DTE's stage kits.
btw thats a yank 3600rpm stall converter right?
Old May 22, 2012 | 02:06 AM
RonSSNova's Avatar
RonSSNova
Hi,
I bought a used 3 rib 3.42 diff here on the forum. They do come around from time to time. If I remember right, it was $400.
I didn't change gears. I just added the DTE left and right shafts, C6 posi clutches and the DTE belville springs. I bought all the seals etc from GM through Richie Rich here on the forums. I didn't replace bearings etc. They were fine.
And yes, a Yank SS3600, also bought here on the forum new in the box for half off because the fellow sold his car before installing it.
Good luck!
Ron
To A4 Diff TT install
