ac issue?
Old May 24, 2012 | 09:05 PM
Steven Burgess's Avatar
Steven Burgess
Default ac issue?
I have ice cold ac coming out the two passenger dash vents. Warm air coming out the drivers side vents. It seems as if the climate control adjustment is working properly because I can turn it up to increase the temp.
Do the vents get stuck on the c5's? Any ideas would be appreciated.
Steve B.
Old May 24, 2012 | 09:07 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
1)Low freon...
2)broken actuator
3)loose/ broken vacuum line
most likely #2 or #3
do a search there are tons of threads about this very topic...
Old May 24, 2012 | 10:06 PM
dmarkshark's Avatar
dmarkshark
IF you know how to check your DIC for codes, see if there is anything for the HVAC and post back.
Old May 24, 2012 | 10:10 PM
Steven Burgess
I'll get a scan done as soon as I get a chance. Thanks for the posts.
Steve B.
Old May 24, 2012 | 10:30 PM
jrose7004's Avatar
jrose7004
The 98 that I used to have would do that when it needed freon.
Old May 25, 2012 | 09:19 AM
pewter99's Avatar
pewter99
these systems are very sensitive to freon levels so being down just a bit can be an issue....unfortunately that would mean you have a leak. You can get the blend door reset with a Tech II but if it is a freon issue it won't matter.
I know my actuator is screwed up and I swapped head units with an 04 and solved that issue...it was easier than me getting to the actual actuator
Old May 25, 2012 | 09:57 AM
dmarkshark's Avatar
dmarkshark
You don't need a scan, everything is through the DIC. DO a search for how to read the DIC.
Old May 25, 2012 | 12:50 PM
Steven Burgess
Thanks for the replys.
I'm not showing any codes on the dic.
I reset the battery today and it acted like it might start blowing colder air but than became warm again. I'm going to give the charge a boost this weekend and see if this helps.
Thanks again,
Steve B.
Old May 25, 2012 | 12:52 PM
BigGun's Avatar
BigGun
How does replacing the head unit w\2004 solve an actuator issue?
Old May 25, 2012 | 02:16 PM
pewter99's Avatar
pewter99
the control units after 01 have a built in logic circuit that compensates for the screwed up actuator...
here is a write up with pics for replacing the actuator as well as a few other nice articles...scroll down to the 3rd or 4th article, it mentions the pre 01 actuators
http://www.circlecitycorvettes.com/tech_tips.html
Old May 25, 2012 | 03:30 PM
Steven Burgess
My pressure guage was way off. Probably because I left it attached to the refrigerant can all winter. Anyhoo, bought a new guage any refilled and wall-a....cold air on both sides.
Not sure how the thing can blow ice cold air on one side of the car but not the other just because it's a little low, but that was the case.
Steve B.
Old May 25, 2012 | 04:40 PM
pewter99's Avatar
pewter99
Steve B.
yeah, probably should have mentioned that from the start
these cars are very picky...just a little low and you get strange things happening
To ac issue?
