x pipe w/cat delete-CODES
Old May 25, 2012 | 01:28 PM
Torch Vette's Avatar
Torch Vette
Default x pipe w/cat delete-CODES
IF I INSTALL AN X PIPE WITH CAT DELETES USING THE ORIGINAL SENSORS & LOCATIONS, WILL I HAVE ANY CODES THAT WILL NEED TO BE REMOVED/RESET.
2001 COUPE, STOCK MANIFOLDS AND Ti exhaust.
Any help or advise would be appreciated.
Old May 25, 2012 | 02:52 PM
The Wrench's Avatar
The Wrench
Yes, you'll set fail codes on the after-cat O2 sensors. you will need to get those signals deleted via tuning software (LS1 Edit, etc) or you can use O2 "simulators" plugged into the rear cat harnesses.
You may also experience some very loud backfiring occasionally when winding up beyond 4000 RPM and coasting back down.
DG
Old May 25, 2012 | 03:12 PM
Torch Vette
Thanks for the feedback, don't want to get in to all of that..
I'll look for a Stock X Pipe...keeping the Cats etc stock..
Old May 25, 2012 | 07:56 PM
SR-71's Avatar
SR-71
I ran all sensors in my catless LG X-pipe untuned and I got a "slow to switch"code from the O2's. I replaced them with new sensors and reset the ecu and the code didn't pop back up for about a year. I got a tune with my cam install and they took care of any code problems with the tune.
Old May 26, 2012 | 08:54 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
,ine will come on every once and a while but clear it and is fine for some time. I went months before a tune and it ever became an annoyance factor
To x pipe w/cat delete-CODES
