Clunking after ZO6 Sway Bar Install
Old May 23, 2002 | 01:11 AM
GmasterB's Avatar
GmasterB
Default Clunking after ZO6 Sway Bar Install
I installed the ZO6 sway bars and end links on my coupe last week. Followed all the directions, torked links to 53lbs, and every thing was perfect. Today on my way home, the thing was clunking like crazy!! Is there some kind of break in period with these, or do you think something is wrong? I really need some advice...
Old May 23, 2002 | 02:28 AM
allanlaw's Avatar
allanlaw
Default Re: Clunking after ZO6 Sway Bar Install (GmasterB)
Something is wrong - there should not be any clunking.
Old May 23, 2002 | 04:32 AM
Sam Lin's Avatar
Sam Lin
Hey, tighten down the endlink nuts more, ignore the published torque settings and go for as tight as you can get it, it should solve the problem.
Sam
Old May 23, 2002 | 09:37 AM
Face's Avatar
Face
Default Re: Clunking after ZO6 Sway Bar Install (Sam Lin)
Sam
I agree. I had the same problem, and cranking down on the endlinks solved it.
Old May 23, 2002 | 11:37 AM
mbtc5vette's Avatar
mbtc5vette
I have the same setup installed and haven't had a problem. If it's not the end links, you may not have had one of the bushings seated properly in its bracket when you installed it and subsequent flexing might have worked it a little loose. Double check all the end links and bushings and you should find the culprit. :cheers: :seeya
Old May 23, 2002 | 08:40 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I also had clunking, the metal end links were lose.
Old May 25, 2002 | 12:23 AM
GmasterB's Avatar
GmasterB
Default Re: Clunking after ZO6 Sway Bar Install (wallstAL)
I gorilla tightened the end links and the clunking is gone! Thanks fellas for ur help.... :smash:
Old May 25, 2002 | 12:30 AM
ElDiablo's Avatar
ElDiablo
Make sure that they are new. I had the same problem till Hotchiks send me new upgraded endlins for free.
Old May 25, 2002 | 11:36 AM
2001 Red Coupe Bandit's Avatar
Default Re: Clunking after ZO6 Sway Bar Install (ElDiablo)
Definately torque the hell out of the end links. That is what seems to cause noises if not tightened enough!
Remeber, HOLD the Torque Wrench and TURN the BOLT!! This makes it much easier.
I installed the Z06 Sways and never any noises.
The Bandit................
Old May 25, 2002 | 08:52 PM
AFVETTE's Avatar
AFVETTE
I too installed the Z06 bars and not a peep. Love the new feel to the car now.
Tom
USAF Retired
Old May 29, 2002 | 12:32 AM
John Wiz's Avatar
John Wiz
Sam
Thank you, Thank you. Been having the same problem, checked every nut and bolt under the car except the endlinks. After ready this post, I realized the knucklehead that was going to install my B&B's (I stopped him, but not soon enough) had loosened the drivers endlink. Went out and checked it, sure enough they were loose, tightened them and the clunk is gone :yesnod: . I love this place.
To Clunking after ZO6 Sway Bar Install
