header install
Old May 26, 2012 | 08:41 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default header install
I am getting ready to do my headers and I have searched high and low to find the answer to this but can I install the headers from under the car if I have it on my lift? The only thing I can find is of installs from the top.
Old May 26, 2012 | 08:42 PM
baxsom's Avatar
baxsom
talked about a lot. it can be done with jackstands
Old May 26, 2012 | 08:49 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Most are saying the jack stands are so you have clearance when you put them through from the top...
Old May 26, 2012 | 09:02 PM
RonSSNova's Avatar
RonSSNova
It will depend on whose headers of course.
I have XS power and they both go in from the bottom.
A lift would be ideal.
I am on jackstands and the car is 18" in the air measured from the frame on the side. I just measured it. They would NOT go in at 16", at all.
Do you not have instructions? Or are they used headers?
Ron
Old May 26, 2012 | 09:07 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Ron
they are XS and used but this what i wanted to hear I have 6 feet of clearance
Old May 26, 2012 | 09:10 PM
99Vision's Avatar
99Vision
Did mine on jackstands. Passenger side from the top, drivers side from the bottom. Needed about 19" of ground clearance for the lg streets. Toque has a nice write up for this install..
Old May 26, 2012 | 09:41 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
All of the china headers I've seen hit the bellhousing on the driver's side, maybe they got that ironed out? let us know how it goes
Old May 26, 2012 | 09:55 PM
RonSSNova's Avatar
RonSSNova
Installed my used "china" XS headers prior to coating. They fit excellent. And they are very high quality. I removed the air tube connections. The tube was thick and they weren't going to fall off due to vibes like some of the fancier headers have experienced.
I also cut the rear tubes in sections to add some extra round mufflers. Same story. Nice thick tubing.
Although like C5vette211 I bought mine used, I wouldn't hesitate to recommend them.
C5Vette211, 6ft ought to do it! I'm jealous!
A tip you might not need because you have a lift. We removed all of the wiring and the starter on the pass side to get it to fit. It slid in like butter then! Drivers side practically falls in place.
Ron
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Will do.
Old May 26, 2012 | 10:17 PM
warren s's Avatar
warren s
As long as the XSPower headers are in good condition and are not bent in any way, the worst you will have is maybe needing to loosen the starter.
Your next problem may be thinking of what to do with the money you saved.
Old May 27, 2012 | 01:00 AM
cdkcorvette7's Avatar
cdkcorvette7
This is a good idea because it'll give you an opportunity to heat-wrap the starter while it's out. The LT's will put out a lot more heat than the stock manifolds and wrapping it should help to extend the life of your starter solenoid.
Old May 27, 2012 | 01:07 AM
RonSSNova's Avatar
RonSSNova
Heat is the reason I'm having mine coated. Reading here I always hear about melted wiring, so I thought it made sense.
I'd like to also look into making new batt cables that have more header friendly routing.
Besides, they don't stay nice and shiny like when they were new.
Mine will be coated flat black 1800 deg F.
Ron
Old May 27, 2012 | 08:38 AM
tim32311's Avatar
tim32311
http://huronspeedproducts.com/C5_Headers_X-pipe.html
Step by step install instructions for XSPower headers - from the bottom.
Tim
Old May 27, 2012 | 12:33 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Tim
Thanks Tim this is what I was looking for.
Old May 27, 2012 | 02:28 PM
tim32311's Avatar
tim32311
You're welcome C5vette. The instructions are spot on, the XSPower headers are easy to install and great quality. Also contrary to previous info they do not hit the bell housing nor do they need bending, heating, praying over, blessing from The Pope or any such nonsense. Coating or wrapping is your call. But John at XSPpower advised me it was not necessary.
I live in Fl and we have more than our share of 100 deg. days, but heat has not been a problem. Enjoy.
Tim
Old May 27, 2012 | 07:17 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Tim
Where in fl are you at? I did not plan on doing any coating. I will prob do heat sleeves on the wires and engine mounts but thats it.
Old May 27, 2012 | 07:34 PM
tim32311's Avatar
tim32311
Tallahassee. I did not use heat sleeves, have not had a problem. Other than the headers, z06 ti catback, LS6 intake, and Blackhawk CAI my car is stock. Have not even had it tuned yet. T'was a nice 97 degrees here today.
Tim
To header install
Old May 27, 2012 | 11:10 PM
lionelhutz's Avatar
lionelhutz
My XSPower had the AC line really close. I bent it out towards the frame at the compressor end. I just hooked a bar clamp in through the wheel well and tigened it a bit to pull the line away from the header. They must install from below unless you drop them in place with the heads off.
Old May 28, 2012 | 09:18 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I will have to try this. I had to take a step back and hit it again tomorrow, I started breaking stuff I used the link posted above with the instructions and I didnt need to remove the coil packs and such on the passenger side. when I went to take the header out from the bottom on the drivers side I ran into some issues. so I am going to take off the drivers side coils tomorrow and just take it out the top then install from bottom. Passengers side went in like butter but I sheered a terminal on my starter when I was removing it :/ I am thinking about going back to my stock cat back does anyone know of a 3" to 2.5" coupler with flanges?
Old May 31, 2012 | 07:37 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Headers went in nicely and sound great and after my tune felt like a million bucks!!
