having serious probs, with my c5
Old May 30, 2012 | 03:37 PM
Kevin Faison's Avatar
Kevin Faison
Cruising
Default having serious probs, with my c5
anytime i get on it the car stalls, returns to a real rough idol, the pedal is nonresponsive, falshes ENGINE POWER LOSS across the dash display, and traction controll light comes on, cut the car off wait i few sec's crank it back up, back to normal, i have a odb tester but the code it reads isnt in the book,, P1515 WTF can anyone help???
Old May 30, 2012 | 03:40 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
sounds like you have a leak at the MAF / airbridge connection or airbridge throttle body....you may also want to pull it loose and make sure there are no obstructions...back in the day there was a rubber piece that would come loose and block air flow or get stuck in the throttle body
Old May 30, 2012 | 04:30 PM
Kevin Faison
Cruising
Default OMG thats it, thanks dude
I have a dual flow air intake w carbon fiber power duct, that did come loose and was giving me fits untill i found where it was leaking the duct was pinched, but under it below the T.B is an open tube ive never noticed before, and can find where it goes from there.
Old May 30, 2012 | 04:42 PM
AllVette's Avatar
AllVette
Old May 30, 2012 | 04:46 PM
Kevin Faison
Cruising
Default thanks man c
i do c something black inside the tube,,? let me check that and c whats up? t[/QUOTE]
Originally Posted by Kevin Faison
I have a dual flow air intake w carbon fiber power duct, that did come loose and was giving me fits untill i found where it was leaking the duct was pinched, but under it below the T.B is an open tube ive never noticed before, and can find where it goes from there also i do c something black inside the tube,,? let me check that and c whats up? t
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have an issue with your THROTTLE BY WIRE system.
Use this procedure and read ALL your DTCs. If there are a LOT of DTCs, clear them ALL.. When the PCM goes into redduced power, immediately read the DTCs with out turning off the ignition:
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
You can read the DTCs while the engine is running. If you turn the engine OFF and then back ON, that can clear some DTCs that may be important with identifying a problem. One example is a Misfire DTC (p-0300) If the engine is shut down, the DTC will clear.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old May 30, 2012 | 05:09 PM
pewter99's Avatar
pewter99
so....is it fixed?
Old May 30, 2012 | 05:25 PM
Kevin Faison
Cruising
Default working on it
getting ready 2 take it out 4 a spin
so....is it fixed?
Old May 30, 2012 | 06:16 PM
Kevin Faison
Cruising
Default Yes!!!!
THANKS TO ALL YOU GUYS WHO CAME TO MY RESCUE!!! anything i can do to help anyone else please let me know!!
OTE=pewter99;1580946184]so....is it fixed?[/QUOTE
Old Jun 13, 2012 | 11:29 AM
Steve L's Avatar
Steve L
How did you fix it ? Im having the same problem with my wifes C5
Old Jun 14, 2012 | 06:31 PM
Kevin Faison
Cruising
yes it was a easy fix, the vararam velocity stack had somehow shifted in the duct and caused a restricted air flow.
To having serious probs, with my c5
