3.91s or 4.11s??
My car flat screams off the line and I'm in the power band whenever I need to be. I've never felt like I have to let the engine build power. It's just there when I want it. No spinning up the engine to get there.
Luckily I live in a small town and the LEOs aren't everywhere because my new favorite thing to do on my nightly honey-do errands is miss a turn just so I can pull a U-turn and fishtail coming out of it.
Good luck with your decision and if you decide to get your diff built I highly recommend Rick Kim with RKT56.
BTW all C5 come with 3 rib diffs starting on 2002. Some late 2001 models came with 3 ribs also.
the most common diff for road racing / track days is the stock 3.42
and of course if talking real road racing, then you have tech rules to follow. But for just track days the 3.42 is just fine.
a few ppl have gonig to a 3.73. The 4.10s or 3.90 was just way too much shifting, and the car was speed limited to about 145-147 mph on the longest straights. ( red line 4th gear )
Plus with the 4.10s or 3.90s the trans and diff would heat up much more then normal so the trans and diff coolers where needed. plus a big arz oil cooler for the engine too.
What may be a an other option which more guys do is take out the MN12 and replace with an MN6 trans. plus brass shift forks.
the 2-3, and 3-4 comb in the MN6 is a better gear ratio then the 2-3 and 3-4 combo of the MN12 for a road course.
the MN12 2-3 gear is too low for most road course, and the 3 to 4 combo is too wide between the gears.
Or just a close ratio box of the GM motorsports box or the ZR1 ratios with the 3.73 rear gear. That will keep your engine right in the sweet spot for torque and HP. Then again, big dollars and big coolers are needed. ( What the hell put in dog rings gears for no lift shiting
) dont forget a clutch too. the stock GM clutch is OK but not great. the Spec II seams to be the most popular for road course guys.
Like any modifications, deep pockets are a blessing or a curse.
Good Luck on that
80 mph cruising I am in 3rd gear occasionally 4th . never 5th
