My Cruise control is working intermittently and now my active handling light is coming on every couple of minutes in straight, level steady speed driving.
I have adjusted my cruise control sensor at the clutch.
Any one have any ideas where I should start looking?
Any help would be appreciated.
Reason: Additional information
The PCM disengages the cruise control operation based on the information received from the TAC module. The TAC module monitors the signal circuits of the following switches:
• The On/Off switch
• The TCC/brake switch
• The stop lamp switch
• The CPP switch
The PCM inhibits the cruise control operation when any of the following conditions exist:
• A cruise control system related DTC has been set.
• The vehicle speed is less than 40 km/h (25 mph).
• The vehicle is in PARK, REVERSE, NEUTRAL, or 1st gear.
• The engine RPM low.
• The engine RPM is high.
• The vehicle speed is to high.
• The system voltage is not between 6 volts and 16 volts.
• The antilock brake system/traction control system is active for more than 2 seconds.
I just tried to pull codes from the DIC by hitting the options button and then the fuel button 4 times. According to the DIC, there are no codes.
My steering wheel is straiht going down a straight & level road and I have not changed the tire sizes.
I'm not sure what an AH light is, please let me know, Any have ay other ideas?
Thanks for the reply, AH - Active Handling! I've had a rough day, my brain must be asleep.
My Active handling notice does not stay on, it comes on and then goes out and comes on again within seconds.
I had the dealership change mine both times. The first time it was under warrany, not so much the second time. I didn't want to mess around with the air bag stuff. Just for reference, I think it was about $400 for the part and labor.
