ABS Removal??
Old Jun 1, 2012 | 11:28 PM
FRED HAMBLE's Avatar
FRED HAMBLE
Default ABS Removal??
How difficult is it to remove the ABS so I can send it to be repaired??
How do I do it??
Fred
Old Jun 2, 2012 | 01:36 AM
Jnape's Avatar
Jnape
Many components are involved with ABS function. The EBCM is the valve/electronics assembly. The ABS pump is a usual suspect. What have you already troubleshot?
A stuck pump can usually be cycled by either many ABS activations or by jumping the pump itself.
If your EBCM is toast, you need to find a used replacement.
Old Jun 2, 2012 | 01:37 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How do I do it??
Fred
FRED
First,,,,,,,,,,,,,,,,,,,,,,, What issues are you having?? What DTCs are present??
The ABS Fixers can usually only fix a limited number of issues. The 1214 dtc is one of the issues that they fix.
Some issues CAN NOT be fixed.
There are SIX screws that secure the EBTCM to the BPMV
Three on each side:
The module is GLUED/sealed to the BPMV and will be difficult to pop loose.
Make sure you seal it back on.
To ABS Removal??
