My 2002 Z06 had a valve spring fail on the way home from work. The valve didn't drop and I replaced the spring with a new yellow spring yesterday. Now that it is back together, it idles and sounds fine. When I get on the gas at all, it starts a whine that I've never heard before. From the symptoms of a broken valve spring, why would this whine start out of nowhere? What could have happened when it broke to have caused this?
Hard to tell from the video, but the noise doesn't appear to be the same frequency as a valve would be. Since the motor is idling, I would expect more of a "tick" "tick" type of sound if related to the valve or pushrod. It almost sounds like the alternator fan scraping or something of that nature because the frequency is much higher. What was removed during the spring replacement? Also, did you replace all of the springs?
Yes, plan to replace them as soon as possible. Most likely going to order dual springs and do a cam at the same time.
Feeling lucky? I guess you figure that spring was ready to fail and the others are still good? Really...you got extremely lucky with no damage on a valve spring failure. Talk about pushing your luck...took me less than 3 hours including a beer break to do mine. Used LS6 springs will sell here, so you have no excuses.
