CLB Installed and Still Locked
Old Jun 6, 2012 | 04:50 PM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
Default CLB Installed and Still Locked
My apologies for asking about such a common problem, but I'm stumped.
My '99 FRC locked up the other day. I thought that the previous owner (my nephew) had installed the CLB but it turned out he had only done the dealer recall. My good luck was that I had put 50,000 miles on the car without a problem.
I ordered a CLB and installed it. It locked up.
I removed fuses 25 and 29, waited and reinstalled and it's still locked.
I did not remove the K harness, nor could I identify the dealer installed relay situated by the BCM to remove and jump it.
What did I do wrong?
Could someone post a picture of the offending relay?
I looked for pins 30 and 87 (the ones that needed to be jumped), but I couldn't identify those either. Does someone have a picture of their approximate positions?
I wouldn't ask, but I've read thirty some pages in the sticky and I thought that what I've done so far would get me going.
Here's a link to a large image of my BCM:
http://i1209.photobucket.com/albums/...tte/BCMlrg.jpg
and a smaller version:
dan k.
Old Jun 7, 2012 | 12:30 AM
1986coupe's Avatar
1986coupe
Which CLB did you install?
Old Jun 7, 2012 | 02:02 AM
_r2h's Avatar
_r2h
Might be a mechanical failure of the locking mechanism itself. If you have one of the cigarette lighter unlockers you can try and and shake the steering wheel back and forth. Failing that, I'd imagine the locking mechanism would need to be removed.
Note: I'm far from an expert on the CL.
Old Jun 7, 2012 | 07:14 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by 8VETTE7
Check your PM's. Second PM corrects an error in the first one.
Do share!
Thanks,Matt
Old Jun 7, 2012 | 11:56 AM
photonhunter
Corvettes of Houston.
Just to make sure that the problem wasn't a low battery, I put the battery tender on last night, but I think that 8VETTE7 has given me a push in the right direction.
I'm headed out to the garage now.
I'll let you know how I make out.
Funny how this happened when I'm just a few hundred short of a 100,000 miles (the car, not me. I've got considerably more miles. <g>).
dan k.
Old Jun 7, 2012 | 12:36 PM
lionelhutz's Avatar
lionelhutz
It will never unlock if the CLB is installed since the CLB install disconnects the locking motor.
Old Jun 7, 2012 | 05:03 PM
photonhunter
Success!!
I had read some posts that said the relay removal and jumper install might not be necessary, but that was not the case for me.
A big public thank you to 8VETTE7 for pointing me in the right direction.
Whenever I successfully complete a job, I frequently like to quote Red Green "If women don't find you handsome, at least let them find you handy". <g>
dan k.
Old Jun 7, 2012 | 05:35 PM
Corvette_Ed's Avatar
Corvette_Ed
Please provide some detail on what you did to solve your problem for others who might experience the same. Glad to see that you've got your problem fixed.
Old Jun 7, 2012 | 06:50 PM
gotz06?'s Avatar
gotz06?
8VETTE7 is the expert on these problems!!
Old Jun 8, 2012 | 01:01 PM
photonhunter
Originally Posted by Corvette_Ed
Please provide some detail on what you did to solve your problem....
There's not much to tell, Ed. I simply stopped short of the finish line in my first attempt.
I had read some posts that said relay removal might not be necessary in some instances. In my case it was necessary.
My car came with an aftermarket stereo that can puncture eardrums when turned up to 11. Some of the wiring for this stereo was hiding the relay that I needed to remove. Once I removed the relay and installed the jumper all was well. It's all detailed in the sticky.
dan k.
To CLB Installed and Still Locked
