Strange Cruise Control behavior...
Old May 24, 2002 | 10:45 AM
chuckster's Avatar
chuckster
Default Strange Cruise Control behavior...
After coming home from my Richard Petty experience
I hit the on-ramp to the Turnpike pretty hard.. I had T/C kick on when I hit 3rd...
And I kept going to ill I got to 120..Then I back down to 79mph and tapped the cruise control button and NOTHING happened...Weird...I thought...must have died.. it work on the way up.. :confused:
Kept trying to set it for the next 1/2 hour.. Nothing.. then I had to pay a toll on the TPK and stopped. When I got back to 79 again the Cruise WORKED!
I am thinking it had the smarts to see T/C went on at about 60mph and that the roads were dangerous i.e. raining (NEVER USE CRUISE in the RAIN)
Once I stopped it reset the conditions. What do you think?
Old May 24, 2002 | 11:22 AM
lotzahp's Avatar
lotzahp
Default Re: Strange Cruise Control behavior... (chuckster)
maybe......wouldn't surprise me either
Have you ever set the cruise HIGHER than 79 before? I don't think I have, so I wonder if there could be an upper limit to setting the cruise speed.
Old May 24, 2002 | 11:24 AM
chuckster's Avatar
chuckster
Default Re: Strange Cruise Control behavior... (lotzahp)
I have set Cruise at 90..works fine :smash: :smash: :D
Old May 24, 2002 | 11:38 AM
BikerDuude's Avatar
BikerDuude
I had the same thing happen on a long road trip last month. I noticed that my Cruise Control would not engage, like you described. Some friends that were following me called to tell me to quit riding the brakes. Well I wasn't doing that at all. It seems that my brake pedal had not returned all the way, leaving my brake lights on, and prohibiting the cruise control from engaging. The remainder of the trip home I would check the CC to see if it would come on, when it wouldnt I would lift up on the brake pedal with my toe and it would work. I think there is a TSB on some booster or something.....
Old May 24, 2002 | 11:22 PM
SAXN8R's Avatar
SAXN8R
Default Re: Strange Cruise Control behavior... (BikerDuude)
Bikerduude, you beat me to it. Check to see if this is the problem chuckster. the same thing happened to me on my '01. Looks like it's off to the dealer for you! Good luck!
Old May 25, 2002 | 09:04 AM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
HI there,
Along the same vein as the booster, you may also have a slightly misadjusted brake switch, which will also create the same concern.
I would have a look at this as well.
Maybe you will NOT have to see the dealer.
Besttoyou, c4c5 :crazy:
Old May 25, 2002 | 12:42 PM
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I've set it @133 AFTER the active handling was triggered at 150.
(hit a bump in the road)
No lectures please... this was all done at the Silver State.
Another C5 owner said he has been on cruise at 162. I don't think that there is a limit (unlike the C4s which seemed to be at 120).
:cheers:
Old May 25, 2002 | 12:53 PM
jschindler's Avatar
jschindler
Default Re: Strange Cruise Control behavior... (c4c5specialist)
Hey C4C5. Nice to see you back "over here". Not only are you very knowledgable, but a class guy!
Old May 25, 2002 | 07:03 PM
Sam Lin's Avatar
Sam Lin
Can someone let me know where/how exactly to adjust the brake switch? My CC rarely works unless I use my foot to hold the brake pedal UP, so I'm pretty confident that the switch is the issue, and I would like to avoid a dealer visit if possible.
Sam
Old May 26, 2002 | 08:44 AM
c4c5specialist
Default Re: Strange Cruise Control behavior... (Sam Lin)
Hi there,
Simply remove the lower dash hush panel, and look at the top of your brake switch. You will see a switch, sitting in a plastic collar, within the brake pedal assembly.
Push the switch forward, against the brake pedal, until you see the pedal start to move forward, and you hear a ratcheting type sound. Then simply pull up firmly on the brake pedal, until you hear it make the same sound. Do NOT yank on it, smoothly pull it up.
This should set your brake switch correctly.
[Modified by c4c5specialist, 6:45 AM 5/26/2002]
To Strange Cruise Control behavior...
