Super Charging vs Crate Engine
Old Jun 11, 2012 | 08:37 AM
bontrager's Avatar
bontrager
Default Super Charging vs Crate Engine
I was considering supercharging my LS1 vert until I read that the boost doesn't really come and is not reached until 1500 rpm or greater; so not instantaneous. So you don't feel it at 700 rpm in first gear?
Is this correct?
Would a crate engine GM LS376, 525 hp and 489 tq be a better option for an instant send off in first gear. Although that torque is not reached until 4,400 rpm.
http://www.jegs.com/ECatalog/full.asp?page=8
Do you have to go to a bigger block engine to get those results.
I guess that I am looking for immediate results as soon as you hit the gas pedal; it's o.k. to laugh my skin is getting thicker.
Please excuse my technical ignorance.
Thank you
Old Jun 11, 2012 | 09:44 AM
Cybermind's Avatar
Cybermind
Personally, I've always preferred my power from naturally asperated engines. Power is there at all rpm's. I'd go with a new crate motor if it was me.
Old Jun 11, 2012 | 09:48 AM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
Default Corvette Camaro GTO GM Truck perforamnce tuning in Tampa
you want boost while idling ?
The best part about the supercharger application is it runs like stock, until you tip into the throttle, then hold on!
Not all superchargers built boost at the same pace/level. Determine what you use the car for the most. Rear mount units feel differant than front mounts. E-Force builds power differant than ProCharger.
If you use the car for quarter mile racing, you may want to consider a differant unit than a road racers.
Then when you did your homework, call Chris at Eastcoast Superchargers.
www.TampaTuning.com
Old Jun 11, 2012 | 09:53 AM
rebelheart's Avatar
rebelheart
Boost that early would only give you more traction problems.
Old Jun 11, 2012 | 12:57 PM
cdnguyred88's Avatar
cdnguyred88
Originally Posted by 8VETTE7
My magna charged 04 dumps the boost until about 2200 RPM. That can be changed. If you have boost at RPM's much below that the car will be on boost ALL the time. Not sure I would want to pay the fuel bill for a car that was always on boost much less the longevity unless it were a track only car. Cruising on the highway at 75 in 6th gear my RPM's are about 1500. I would NOT want the car on boost in those conditions. Similar situation in city stop and go driving. Always on boost is something I would not want. A little more mash on the go pedal gets me into boost quickly when I want it.
Old Jun 11, 2012 | 01:17 PM
CHJ In Virginia's Avatar
CHJ In Virginia
If you are looking for IMMEDIATE get up and go at low RPM, forget about a blower. Change your rear gears to a 4:10 ratio. Response will be immediate and snap your head back compared to stock ratios. Cost will be substantially less than either big cubes or a blower.
Old Jun 11, 2012 | 01:31 PM
chaase's Avatar
chaase
St. Jude Donor '12
You don't want boost too early. It will just be a smoke show when you try to launch. Centrifugal vs Roots type give a different profile. None of them give you boost immediately since you would be inhaling fuel for no benefit as you cannot get traction down there anyway.
For more immediate power, you can add gear or more cid.
Old Jun 12, 2012 | 06:20 AM
bontrager's Avatar
bontrager
First of all, I want to thank everyone for there answers and knowledge.
I will go with changing the gear ratio in the diff ( either 390 or 410). Seems to be exactly what I'm looking for.
I had read a few months back that the change to 410 would make first gear useless.
Can you comment on this.
Thank you.
Old Jun 12, 2012 | 08:50 AM
CHJ In Virginia
You are going to run out of first gear quickly with 4:10's. Two recommendations 1) Do a search in the C5 general and tech sections for threads on gears. There have been a bunch over the past several years, lots of good info there. 2) Find someone locally that has made the swap and get a ride. You can post in the regional section for your area and probably get some response.
Old Jun 12, 2012 | 09:00 AM
chaase's Avatar
chaase
St. Jude Donor '12
Thank you.
If you want to supercharge, then you don't want more gear. The lower gears will be even more useless. Head cam and gears go together, supercharging and gears do not.
Old Jun 12, 2012 | 07:09 PM
Kooker01Z's Avatar
Kooker01Z
How often are you even below 1500 rpm's and actually needing boost in the first place? If you're planning on using the boost for any significant reason I'm assuming you'll be racing or trying to go fast for some reason and will almost certainly already be above 1500 rpm's. So, why would it necesarrily matter if it doesn't kick in til 1500?
Old Jun 12, 2012 | 07:52 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
My vote is a big cube n/a beasty.... Our 457 will smoke most s/c on a stock engine and be 100% more reliable. Simple as that. These engines are not built for boost. Abuse one the way you can a proper built engine and it wont last long.
Old Jun 12, 2012 | 07:55 PM
lucky131969's Avatar
lucky131969
Originally Posted by 99blancoss
....... and be 100% more reliable.
100% huh? So, you are saying that SC engines are not reliable at all?
Old Jun 12, 2012 | 08:00 PM
99blancoss's Avatar
099blancoss
Former Vendor
quote for you:
Yes our 457 will make more power and be more reliable than boosting the stock engine be it an Ls1, Ls2, Ls3, LS6. Pretty straight forward.
Old Jun 12, 2012 | 08:07 PM
lucky131969
quote for you:
You must be a great salesman......rock on..
Old Jun 12, 2012 | 08:20 PM
99blancoss's Avatar
099blancoss
Former Vendor
Just stating facts. Stock engines are not built for boost from GM unless its one of their boosted offerings. Compression, piston material, rings .. bunch of differences between an engine built for boost and one for n/a and you very well know that. It's not hard to say what is said at all and its the truth.
Your childish bantering is simply just that.. have a nice night, I wont respond to your BS anymore. Far to many other things to do
Old Jun 14, 2012 | 09:06 AM
bontrager's Avatar
bontrager
What is CID?
Thank you.
To Super Charging vs Crate Engine
Old Jun 14, 2012 | 09:20 AM
AU N EGL's Avatar
AU N EGL
Old Jun 14, 2012 | 09:36 AM
bumble-z's Avatar
bumble-z
What is CID?
Thank you.
My only guess ..., Would be cubic inch displacement.????
Old Jun 14, 2012 | 09:53 AM
chaase's Avatar
chaase
St. Jude Donor '12
Yup. Cubic Inches of Displacement.
