Muffler Hardware
Old Jun 11, 2012 | 12:12 PM
tentuna's Avatar
tentuna
Default Muffler Hardware
Just purchased Z06 mufflers and was wondering do you have to change the muffler gaskets and are the bolts usually toast, if so does anyone know the thread size and length
Old Jun 11, 2012 | 12:53 PM
bumble-z's Avatar
bumble-z
You should be able to reuse the bolts/nuts & gaskets.
Enjoy the Ti's.
Old Jun 11, 2012 | 01:05 PM
kris6868's Avatar
kris6868
I have always changed or try to change all gaskets whenever I could. It's a standard factory gasket you can pick up any local parts store.
I believe the thread is 7/16". An either 1-7/16" or 1-1/2" lenght.
Old Jun 11, 2012 | 01:49 PM
bmfvette's Avatar
bmfvette
They are plug and play if you're not real aggressive taking the stock mufflers off (assuming your replacing the stock set). You will have to get the rear of the vette real high to clear the axles but it can be done with jack stands and jack (if you don't have access to a lift).
Also, use a straight edge (board, etc.) to align the tips.
To Muffler Hardware
