A/C problems
Old Jun 12, 2012 | 03:05 PM
haydengm1's Avatar
haydengm1
Default A/C problems
I have a 2001 Corvette that has an A/C problem.It has the individual controls for each side.
It only blows warm air on both sides. Unit is charged and I was told the Temperature Valve/Blend Actuators needed to be replaced. Does that sound right ? If so, any words of advice on replacing them ?
Thanks in advance for the help! Gary
Old Jun 12, 2012 | 07:49 PM
dmarkshark's Avatar
dmarkshark
First, read your DIC and see if it is throwing any HVAC codes. Notice if they have a C or H, or HC after them. Any AC work done on the car?
Old Jun 12, 2012 | 10:01 PM
PUMP03's Avatar
PUMP03
Oldtimer
The attached diagram should aid in understanding how the temperature control works.
Old Jul 9, 2012 | 07:40 AM
haydengm1's Avatar
haydengm1
No work has been done on the car. Thanks for your help
Old Jul 9, 2012 | 12:29 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I was reading the other day (searching for answers of my own) that the vent doors need "reprogrammed" or re-initialized. I don't remember exactly what forum it was on, but there was a procedure for resetting the doors after having done a battery replacement. So, if you had the cables off recently, you might do some searching for terms like those above, or relearn, or whatever.
Old Jul 9, 2012 | 02:20 PM
haydengm1's Avatar
haydengm1
Not sure if the problem is fix for good but the a/c is working now. For everyone's information, I unhooked the battery to replace the gears in the headlight motors and when I hooked the battery up the a/c started working.Does that make sense to anyone ?
Old Jul 9, 2012 | 03:51 PM
dmarkshark's Avatar
dmarkshark
Unfortunatly, yes.
Old Jul 9, 2012 | 03:53 PM
haydengm1's Avatar
haydengm1
Would you say it fixed the problem or just delayed the repair ?
Old Jul 9, 2012 | 04:31 PM
K-Spaz's Avatar
K-Spaz
I don't think there is a 'repair'. From what I recall, they are controlled by the electronics in the car and get out of whack sometimes. I thought something more was needed after the battery disconnect, but, maybe I'm remembering wrong and that needs done only if you have not disconnected the battery. In any case, I'm glad it's working for you now.
Old Jul 10, 2012 | 07:22 AM
haydengm1's Avatar
haydengm1
Thanks for everyone's information
To A/C problems
