Headers Dissipating Heat
Old Jun 12, 2012 | 03:38 PM
SoQuick06's Avatar
SoQuick06
Default Headers Dissipating Heat
Please weigh in. I was mentioning to a friend that my turboed Vette was running hotter than usual. I told him that I had checked all of the usual suspects; radiator; cowl; chin spoiler; water/coolant mixture; etc...when his friend chimed in. He works at a well know performance shop, as suggested that the engine block was getting too hot and needed a set of headers to remove some of the excess heat. I've been running without headers since I had the turbos installed over 5 years ago. Is there any credence to this theory? I have scheduled an appointment with my tuner to see if he can assist with this issue.
Old Jun 12, 2012 | 07:24 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi,
When you say hot, how hot. Maybe thermostat not opening all the way?
Not sure why you would need headers if you ran it for 5 yrs the way it is with no issues.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Jun 12, 2012 | 07:32 PM
Lothar34's Avatar
Lothar34
Are the turbos mounted to the manifolds under the hood, or are htey rear mount?
Old Jun 13, 2012 | 09:44 AM
SoQuick06's Avatar
SoQuick06
I don't think that it is the thermostat, because I've changed it out (no kidding) 3 times. And I agree, it wasn't an issue for 5 years, so why now? I am going to re- install my high speed fans this weekend. Wish me luck.
Old Jun 13, 2012 | 09:45 AM
SoQuick06's Avatar
SoQuick06
They are rear-mounted. And that is why what he said really doesn't make sense.
Old Jun 13, 2012 | 10:04 AM
AU N EGL's Avatar
AU N EGL
Ceramic coated headers remove quite a bit of heat from the engine AND cockpit.
Old Jun 13, 2012 | 11:27 AM
WildVettes's Avatar
0WildVettes
Former Vendor
St. Jude Donor '12
Stainless steel is much better at removing heat than the stock manifolds and will run much cooler.
Ceramic coating on stainless headers is purely cosmetic. The only headers that need ceramic coating are the mild steel ones to prevent them from rusting.
Old Jun 13, 2012 | 12:11 PM
SacCityCorvette
Supporting Vendor
When you say "I am going to re- install my high speed fans this weekend."
Does that mean you don't have fans? Maybe I'm missing something.
Old Jun 13, 2012 | 01:38 PM
SoQuick06's Avatar
SoQuick06
I am running the stock fans. I had placed the high speed ones on without a shroud. The stock one had a shroud. I'll have to fashion some kind of shroud for the high speed ones.
Old Jun 13, 2012 | 03:10 PM
StatmanRN's Avatar
StatmanRN
I would think that headers, even coated ones, having a larger surface area, will radiate MORE heat and increase underhood temps. Have never seen temps decrease on any vehicle I've owned after adding headers.
Used to be in the RV business, headers were promoted by manufacters to help cooling on motorhomes. Never saw it help temps, in fact most ran hotter...
I also have an STS setup, stock manifolds though. They say that headers would cost power from cooler exhust temps, that the lower velocity makes the turbos spool slower. Also, that with all the backpressure, there is no flow improvement. So...Don't think youll notice a diference in power or temps with headers but keep us posted.
I did find the vette ran hotter after the turbos but I think it was the intercooler blocking some airflow. I went with an a larger all aluminum radiator- problem solved.
Old Jun 13, 2012 | 03:14 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
[Q
I disagree - ceramic coating helps reduce the outside temps -keeps more of the heat internal to the exhaust and might even help his performance a little bit with rear turbos.. just sayin ....
Old Jun 13, 2012 | 03:17 PM
1stGlance's Avatar
1stGlance
How in the world would coated headers radiate more heat in the engine compartment? That is just not true!!
Old Jun 13, 2012 | 04:22 PM
StatmanRN's Avatar
StatmanRN
I have had Jet Hot coated headers on my Trans Am. While they dont radiate as much as uncoated headers, hold up better, and look nicer they STILL radiated far more underhood heat than stock manifolds.
On the ther hand WRAPPED headers DID make a big difference in underhood temps. But in neither case did they make the engine run cooler.
But thats just my experiance.
I wrapped the exhaust all the way to the turbos on the vette, but never ran it without to compare. Couldnt hurt.
Old Jun 14, 2012 | 09:55 AM
SoQuick06's Avatar
SoQuick06
How large of a radiator? I have a three row aluminum now.
Old Jun 14, 2012 | 12:31 PM
StatmanRN's Avatar
StatmanRN
Same here. Have you flushed the system? Were/are you using Dexcool ar glycol? Did you make sure that something didnt suck up into the radiator behind the intercooler? And last, did you make sure all the air was purged from the system? I had a similar problem with my '95 Vette until I learned how to burp it.
Old Jun 14, 2012 | 03:47 PM
SoQuick06's Avatar
SoQuick06
I'm am officially an expert at burping my Vette. There is no debris that has been sucked into the radiator, and I have tried the 50/50 and 75/25 mixture of water to coolant. And I only use dexcool along with two bottles of water wetter.
Old Jun 14, 2012 | 05:30 PM
StatmanRN's Avatar
StatmanRN
Have you pressure tested? Are you losing coolant? And...worst case senario...head gasket issue?
To Headers Dissipating Heat
Old Jun 14, 2012 | 07:43 PM
B747VET's Avatar
B747VET
Just a thought, but I think that for folks to really help you they might need a little more detail. "Hotter than usual" is a pretty broad description for a supercharged C5. 5 degees hotter? 20 degrees hotter? Hotter at freeway speed? Hotter around town below 40 mph, above 40 mph, with AC on or off etc... etc...
My understanding is that burping is not really an issue for the C5. It basically self purges through that valve at the top of the radiator into the purge tank if the fluid levels are correct.
FWIW, as I recently found out, having too much fluid above the full line in the purge tank can lead to a number of issues including some degree of overheating. If the fluid is well above the full line after shutting down over night it needs to be siphoned down below the line.
Also, FWIW, my average temps have seemed to drop about 3-5 degrees after I had a set of B&B SS shorty step headers installed.
Old Jun 15, 2012 | 11:34 AM
SoQuick06's Avatar
SoQuick06
Hotter than usual means running 238-245. And gushing out of the overflow tank after I shut the car off.
Old Jun 15, 2012 | 11:41 AM
SoQuick06's Avatar
SoQuick06
I think that I might have solved the problem. I pulled the shroud and upper radiator support off, and discovered that the fans were not flush up against the radiator. they were just hanging out about 8-10 inches away. I cinched the up flushed to the radiator and anchored them to the front shroud. Now when I run it hard with the AC on it will get to 228-235, but quickly recovers under calmer driving conditions. Without running the AC it gets to 220-230 under hard driving, but recovers back to about 225 once I back off. This is with the stock fans. I want to see what the high performance fans will do. Will keep y'all posted. Thanks for all of the input.
