No contols on drivers door
Old Jun 16, 2012 | 10:53 AM
red 90's Avatar
red 90
Default No contols on drivers door
All of the switches on the drivers door are inopperable. The fuses are all good, I was putting the window down and it stopped about 2 inches from going all the way down, now none of the switches including the mirrors work... Any ideas?? (02 vert)
Old Jun 16, 2012 | 11:11 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your going to LOVE THIS Recommendation....
Open the door. Grab the rubber accordion tube and shake the crap out of it. See if that fixes it!
The female pins in the connectors in the door A pillar are damaged.
Bill
Old Jun 16, 2012 | 02:51 PM
red 90's Avatar
red 90
Tried your recomondation and it worked. I will wait and see if it heals. Thank you.
Old Jun 16, 2012 | 03:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You just TEMPORARILY fixed it.. The problem will return. To fix it, pop out the rubber tube, fish the connectors out of the chassis hole and unplug the connectors. Examine the FEMALE pins and liik for any that are deformed. You can use a metal pick and bend the toung back up to make a better connection with the male pin.
Old Jun 18, 2012 | 05:14 PM
red 90's Avatar
red 90
You were a great help, Thank you very very much
Old Jun 18, 2012 | 06:46 PM
kris6868's Avatar
kris6868
I believe Mr. Bill have a fix for everything on the vette.
His write-ups has helped me so much and have saved me tons of money...
To No contols on drivers door
