Air Bag light after new IPC install.
Old Jun 17, 2012 | 06:25 PM
cadallante87's Avatar
cadallante87
Default Air Bag light after new IPC install.
Just installed a new IPC to solve my backlight issue and now I'm getting an air bag light. Any ideas?
Old Jun 21, 2012 | 08:01 PM
cadallante87
ttt
Old Jun 25, 2012 | 12:20 PM
cadallante87
Anyone?
Old Jun 26, 2012 | 08:52 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The SDM module is located behind the HVAC unit in the center dash area. Did you disconnect it when pulling the IPC? Also, there are "yellow" connectors associated with the steering column and since I don't know if you lowered the column first or removed it, those yellow connectors could be the issue if you left one disconnected. Warning...do not mess with the yellow connectors with the battery connected. Use serious caution when working with the SDM or any yellow connectors.
To Air Bag light after new IPC install.
