Oil Pressure Low?
Old Jun 19, 2012 | 04:44 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Oil Pressure Low?
I have a question concerning my oil pressure on my 98. I did a search and couldn't find what I was looking for, unless I overlooked it. I noticed that my oil pressure is around 34 while cruising. What is normal pressure at idle and cruising, sorry if that has been asked before, but I am a newb to the C5.
Old Jun 19, 2012 | 10:59 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
normal/// philly joe
Old Jun 20, 2012 | 10:35 AM
DA1984VETTE
Originally Posted by 8VETTE7
What is the engine RPM when you are reading 34 lb?
My 6 speed at 65 in 6th gear is turning under 1500RPM and I don't see much more pressure than that under those conditions.
I guess mine is the normal range then. I forgot to add what gear and the RPM's when I posted. The same 65 6th gear around 1500, so I guess mine is normal. I usually post more info in my posts but I didn't on this one.
Old Jun 20, 2012 | 01:01 PM
Jake@Texas-Speed's Avatar
Jake@Texas-Speed
Cruising
We see most of these motors somewhere around 40psi at hot idle, and should only increase while cruising.
Old Jun 20, 2012 | 01:30 PM
Swaie's Avatar
Swaie
Mine is a 98 and runs about 34 also in 6th about 70mph...I'm going to change it out...I'm use to the fbody's and mine had a ported ls6 pump and was never below 40. Just for piece of mind i guess.
Old Jun 20, 2012 | 01:51 PM
Jake@Texas-Speed
Cruising
How many miles are on that motor?
Old Jun 20, 2012 | 07:12 PM
DA1984VETTE
73k
Old Jun 21, 2012 | 08:39 AM
Swaie's Avatar
Swaie
I have 122000
Old Jun 21, 2012 | 01:09 PM
ZeeOSix's Avatar
ZeeOSix
My '02 Z06 is at 30~32 psi at idle (800 RPM) with 200 deg F, Mobil 1 5W-30. Typically, the oil pressure should increase ~10 psi for every 1000 RPM increase in engine speed (talking about stock oil pumps).
To Oil Pressure Low?
