Hood alignment?
Old May 25, 2002 | 04:24 AM
6699's Avatar
6699
Default Hood alignment?
My hood is just a little to high, right in the middle, where it meets the front bumber.
How do I adjust this in the best way?
Mikael
Old May 25, 2002 | 09:36 PM
C5Cemo's Avatar
C5Cemo
Default Re: Hood alignment? (6699)
The rear mounting holes from the hood to the hinges are slotted. You could loosen all 4 then raise the rear bolts a bit to increase the front slope of the hood...doing so will take an extra set of hands.
I've had my hood off more than once and this is the only way I see it happening. Of course, any change will effect the overall fit of the hood. Does it sit even at the back? Is there any play in the latches when it's closed?
Old May 26, 2002 | 04:49 AM
6699's Avatar
6699
Default Re: Hood alignment? (C5Cemo)
Thank you C5Cemo for you answer!
I have not really noticed anything wrong at the back of the hood, but I will go and take a closer look at it.
Sounds like a good solution though!
Mikael
Old May 26, 2002 | 09:47 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
6699:
I had the identical question, and got a few answers myself. This is apparently quite common. Check out my earlier thread: http://forums.corvetteforum.com/zerothread?id=299861
Old May 26, 2002 | 09:55 PM
alanh's Avatar
alanh
Loosen the front bumper cover bolts and make some shims out of anything that water won't affect and place them under the bumper cover to raise it to the height of the hood, then tighten the bolts.
[Modified by alanh, 7:56 PM 5/26/2002]
Old May 26, 2002 | 11:26 PM
quenchmasterc5's Avatar
quenchmasterc5
I had the same problem. Found out by looking/prodding around the bracket for the front bumper was loose. Difficult to get to, but you will need to check for loose bolts and brackets around the front bumper. Access via the headlight assembly. There are also adjustments on the sides at the top of the fenders to adjust the hood up and down.
AL
To Hood alignment?
