Gas cap issue fuel pressure issue
Old Jun 21, 2012 | 03:31 PM
ssdungeon's Avatar
ssdungeon
Default Gas cap issue fuel pressure issue
Do you guys think a new gas cap will fix this issue?
IF I drive around town for a while and maybe get on it through a gear. When I stop often I hear a POOSHH!!! Then down below the rear passenger marker light on the back fuel escapes. and drissles down.
If I catch it fast enough all I have to do is open the fuel cap and its a LOT of pressure. I mean a LOT.
To stop this I can just put the cap on but not tighten it and it appears to stop this.
My fuel pressure guage is not working on my fuel rail I am wonderring also if its causing fuel pressure issues at WOT.
I have a 97 C5 it HAD the return style system on it until me not knowing better changed it over to the 2000+ model returnless systems.
MY Z has an evap purge around the fuel rail that is not on this car should I try to add one somehow?
Old Jun 22, 2012 | 12:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have modified the vent and emissions evap purge system so that it no lnoger vents properly. Until you do that, your going to have issues. Im surprised that you not throwing a lot of fuel system DTCs unless you have had them tuned out.
YES,, find a system that will match up to your 97 and provide the venting that you need..
Bill
