Diagnostic Trouble Codes (DTCs)
Old Jan 5, 2013 | 01:17 PM
PUMP03's Avatar
PUMP03
Oldtimer
Originally Posted by Erik_Hagglund
Thank you for this list, it has been very helpful!
One question though:
C1272 is suppose to be a code specific to 1997 through 2000 model years..?
So if you have a 2003, with that code, how are you suppose to interpret that? Bad DTC version?
With regard to any of the DTC's related to the Electronic Brake Control Module (EBCM), the list does not adequately explain the differences.
In post 2000 models DTCs C1261 thru C1274 are set when there is a malfunction in the solenoid circuit internal to the EBCM and there are no tests that can be made with the EBCM installed on the car.
On 1997 thru 2000 models the service manual gives specific testing steps to determine cause and possible corrective action.
Suffice it to say that when dealing with the EBCM, the merged DTC code list is not very accurate in showing differences.
Old Dec 19, 2013 | 04:40 PM
Michael1950's Avatar
Michael1950
Cruising
Default Codes
Thank you so much. Great information and effort on your part
Old Feb 23, 2014 | 02:57 PM
James McKee's Avatar
James McKee
5th Gear
Default C5 dtc codes
Thanks for taking the time to do this. I have printed a copy and I am sure it will be very helpful to me in the future taking care of my 2002 corvette C5.
Old Sep 20, 2014 | 04:46 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
I've read a lot and have your code post bookmarked but don't see: 10 PCM 2 codes listed. I reset them thinking a glitch but want to know if there is more to this.
Thanks,
Joel
Old Nov 4, 2014 | 02:55 PM
dustysix's Avatar
dustysix
Default codes c5
[QUOTE=PUMP03;1581132365]I created the attached pdf file with a how-to on pulling DTC codes icluding a list of the codes/descriptions. You can upload the pdf to any smart phone, Ipod Touch or similar device for viewing with the e-reader app for a handy always with you reference.[
/QUOTE]
thanks for that info very complete and simple to read.
Old Feb 18, 2016 | 01:13 PM
Tortorete's Avatar
Tortorete
6th Gear
i have a code C1288 which says steering position sensor circuit. what does that mean? my vet is a C5 2004. thank you
Old Feb 18, 2016 | 03:49 PM
Z06copley's Avatar
Z06copley
I believe that this is the most up to date TSB:
Vehicle: All Technical Service Bulletins
VSES - Warning Displayed, DTC C1288 Stored
Brakes Bulletin No.: 01-05-25-004A Date: November, 2001
TECHNICAL
Subject:
Yellow: Traction Control/Handling Lamp On and Driver Info Center Displays Service Active Hndlg (Handling) (Repair/Reprogram ABS Module)
Models:
2001-2002 Chevrolet Corvette Built Prior to VIN Breakpoint 25106536
This bulletin is being revised to add an additional model year and revise the text. Please discard Corporate Bulletin Number 01-05-25-004 (Section - 05 Brakes).
Condition
Some customers may comment that the "Yellow" message, "Service Traction Active Handling", is illuminated on the Driver Information Center. The technician may find chassis DTC C1288 - Vehicle Stability Enhancement System (VSES) Steering Wheel Sensor Phase A and B. When this code is set, the VSES is turned off, ABS and TCS remain operational.
Correction
Verify the Techline equipment has been updated with TIS software 12 or newer. If it has not been updated, do so now. This software was broadcast to dealerships on 11 /13/01. Disc Number 12 will be mailed November 14,2001.
1. Install the scan tool to the vehicle.
2. Enter the chassis applications.
3. Select F1: ABS/TCS/VSES.
4. Select F4: ID Information.
5. Select Fl: Controller Information 2.
5.1. If the DE Calibration P/N is not 12220685, it will be necessary to update the ABS module.
5.2. If the calibration is already 12220605, refer to the Service Manual, Brakes, Antilock Brake System, Diagnostic Information and Procedures, DTC 1288, SI2000 Document ID 670707.
Important:
The update cannot be performed until fuse # 25 (Body Control Module-Ignition 1, Instrument Panel Control) 10 amp is removed from the instrument panel fuse block which is located on the passenger side of the vehicle (under the instrument panel and under the toe board).
Without removal of the fuse (prior to requesting information), unsuccessful reprogramming may occur.
6. Power down the scan tool.
7. Turn OFF the ignition and remove the key.
8. Remove fuse # 25, (Body Control Module-Ignition 1, Instrument Panel Control) 10 amp.
9. Using the scan tool, perform the usual SPS reprogramming of the ABS module.
10. Power down the scan tool.
11. Turn OFF the ignition and remove the key.
12. Replace fuse # 25, (Body Control Module-Ignition 1, Instrument Panel Control) 10 amp.
13. Verify the ABS DE Calibration P/N. If it is not P/N 12220685, redo the SPS programing procedure listed above.
14. Clear the codes from all the modules.
Old Aug 1, 2017 | 04:55 PM
CPO Rob's Avatar
CPO Rob
Veteran: Coast Guard
Default Dtc
I found this also http://www.corvette-web-central.com/C5DTCcode.html
Old Jul 31, 2021 | 12:11 PM
dt1759's Avatar
dt1759
Cruising
Old Apr 17, 2024 | 07:02 AM
pajones321's Avatar
pajones321
thank you!
