Diagnostic Trouble Codes (DTCs)
Old Jun 22, 2012 | 03:09 AM
PUMP03's Avatar
PUMP03
Oldtimer
Default Diagnostic Trouble Codes (DTCs)
I created the attached pdf file with a how-to on pulling DTC codes icluding a list of the codes/descriptions. You can upload the pdf to any smart phone, Ipod Touch or similar device for viewing with the e-reader app for a handy always with you reference.
File Type: pdf
Last edited by PUMP03; Sep 14, 2012 at 09:49 AM. Reason: Updated pdf 9/14/2012 9:00AM CTD
Old Jul 5, 2012 | 07:11 AM
flyinlow427vette's Avatar
flyinlow427vette
THANK YOU!!!! I was looking for that myself, going to pick up my Z tomorrow!
Old Aug 8, 2012 | 07:44 PM
PUMP03's Avatar
PUMP03
Oldtimer
I updated the pdf to reflect differences between early C5s (1997 to 2000 model years) and 2001 to 2004 models
Old Aug 8, 2012 | 08:59 PM
fas3288's Avatar
fas3288
Default Great Job
Thanks for taking the time to do this! Awesome resource.
Old Sep 13, 2012 | 07:06 AM
Soloontario's Avatar
Soloontario
Under the antilock/traction control system have you got C1225 and C1226 reversed? I have heard from other sources that the C1225 is the Left front and C1226 is the right front.
Old Sep 13, 2012 | 10:07 AM
lucky131969's Avatar
lucky131969
You are correct. C1225 is for the left.
Old Sep 13, 2012 | 10:28 AM
PUMP03's Avatar
PUMP03
Oldtimer
You are correct Sir. I will get that revised and repost the pdf.
Old Sep 13, 2012 | 11:39 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Nice job PUMP03!
Forum Moderators should definitely include this one in the "It's All In Here" sticky.
Old Sep 13, 2012 | 11:43 AM
FRITZM's Avatar
FRITZM
Default DTCs
OP did a great job on this, especially separating the codes for model years. Definitley a Sticky candidate.
Old Sep 13, 2012 | 03:14 PM
lucky131969
Originally Posted by Quicksilver Vert 01
Nice job PUMP03!
It's not a complete list for all C5's. Many 2004 codes are missing.
Old Sep 13, 2012 | 05:52 PM
PUMP03's Avatar
PUMP03
Oldtimer
I didn't realize that 2004 had additional DTCs. I will look into that and correct the pdf if justified.
Also the pdf ha sbeen revised to show C1225 is LF and C1226 is RF.
Old Sep 13, 2012 | 06:17 PM
lucky131969
Not additional......different. For example: on a 97-03, the an AIR check valve malfunction is a P1415 or P1416. On a 2004, the same malfunction is P0491 or P0492.
Old Sep 13, 2012 | 10:19 PM
raosterkamp's Avatar
raosterkamp
Thanks for the info !!!
Rick
Old Sep 14, 2012 | 01:33 AM
PUMP03's Avatar
PUMP03
Oldtimer
I added / differentiated the 2004 specific DTC codes. Hope i got them all.
Old Sep 14, 2012 | 02:11 AM
Quicksilver Vert 01
The P2761 DTC listing and description should be green color-coded.
Old Sep 14, 2012 | 09:01 AM
PUMP03's Avatar
PUMP03
Oldtimer
Thanks. The code is preceded by # and part of the line is green, so it is half a$$ correct - lol. I'll get it fixed and repost.
Old Sep 14, 2012 | 09:53 AM
PUMP03's Avatar
PUMP03
Oldtimer
Green is good. Uploaded corrected pdf at 8:50-AM CDT.
To Diagnostic Trouble Codes (DTCs)
Old Sep 14, 2012 | 07:49 PM
Quicksilver Vert 01
Looks great!
I have them all printed to use for a quick reference when needed.
The color-coded lines, for specific model years, is a big plus.
Old Sep 19, 2012 | 05:50 PM
maxx2200's Avatar
maxx2200
Thank you!
Old Jan 4, 2013 | 05:07 PM
Erik_Hagglund's Avatar
Erik_Hagglund
Thank you for this list, it has been very helpful!
One question though:
C1272 is suppose to be a code specific to 1997 through 2000 model years..?
So if you have a 2003, with that code, how are you suppose to interpret that? Bad DTC version?
