Third gear issue at WOT on nitrous
Old Jun 22, 2012 | 11:38 PM
Formulized94's Avatar
Formulized94
Default Third gear issue at WOT on nitrous
I am trying to figure out a shifting issue I am having. While under full throttle on nitrous I cannot get the car into third gear. All other gears shift perfect, it just will not go into third. On motor only at wot it shifts fine into third.
I do not want to pull the trans out if I do not have to. I put a tick master cylinder in my Fbody and that fixed the same issue I was having in that car. Would any body agree and think the Tick master would fix this issue.
New Slave Cyl
EXO Skel Clutch
Old Jun 23, 2012 | 01:21 AM
Qweklain's Avatar
Qweklain
The master cylinders are notorious for basically "blocking" hydraulic pressure under high RPM shifts for some reason. That is why there is a high demand for the Tick MCs or some people do the "drill mod" to eliminate the restrictors in the feed-line. I think there are three in the C5s? I am sure someone much more in-the-know could assist better.
Old Jun 23, 2012 | 01:26 AM
Formulized94
I am thinking about looking into the tick setup before i decide to pull the trans. It shifts real good otherwise.
To Third gear issue at WOT on nitrous
