blackwing to easy
Old May 25, 2002 | 03:39 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Default blackwing to easy
installed black wing this morning took about 45 mins.would have been faster but couldnt figure how the stock box came out .how does the car breath with that stock air box .drove it a little felt stronger. the streets were wet so i couldnt jump on it like i wanted to . :cool: :yesnod:
Old May 25, 2002 | 03:49 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
Default Re: blackwing to easy (johnnyvettes)
Not very well, that is how it breathed with the stock system! You will really enjoy the Blackwing, IMHO, it is the best single performance mod you can do.
Old May 25, 2002 | 05:40 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: blackwing to easy (Craig2000)
:cheers:
Old May 25, 2002 | 07:04 PM
cortex's Avatar
cortex
Default Re: blackwing to easy (Dale RED 98)
Is the hood seal a requirement for the Blackwing?
Old May 25, 2002 | 07:07 PM
johnnyvettes
CHICAGO CREW !
Default Re: blackwing to easy (cortex)
yes i put the hood seal on it came with exit28 had a good deal on it :cheers:
Old May 25, 2002 | 07:12 PM
LoneStarFRC's Avatar
LoneStarFRC
Not really but still a good idea. Cheap too. :)
Old May 25, 2002 | 07:30 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Senior Member
Cruise-In V Veteran
It is not a requirement but I would highly, highly recommend the hood seal for several reasons. First and formost, it prevents water from getting on the filter element, which could lead to hydrolock on open element filters like the Blackwing. Second, it helps to pressurize the air filter area which gets the filter more air to breath, and thirdly it helps keep your engine bay clean, so in other words get one, they are too cheap not to. :chevy
Old May 25, 2002 | 08:24 PM
DUKE's Avatar
DUKE
:smash:
Old May 26, 2002 | 12:54 AM
HOCKEY's Avatar
HOCKEY
Default Re: blackwing to easy (DUKE)
Did mine in 25 minutes.
Old May 26, 2002 | 01:27 AM
WWK888's Avatar
WWK888
Default Re: blackwing to easy (HOCKEY)
How did you guys get the lower (towards the front) grommets on? I have a hard reaching down there (hood is in the way). Any tips? Thanks..
Bill
Old May 26, 2002 | 07:25 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: blackwing to easy (WWK888)
Bill
...yeah, do what I do...bend waaaaaay over to the point where you pull a muscle in your leg then you can reach.... :lol: :lol: ..no easy way that I know of
Old May 26, 2002 | 07:50 AM
EHS's Avatar
EHS
Craig:
What is hyrdolock?
And how does he rubber weatherstrip hood seal prevent it?
Is this a common occurence with the Donaldson filter?
Old May 26, 2002 | 08:55 AM
AFVETTE's Avatar
AFVETTE
I lubed all the mounting post with silcon and the thing just about installed itself. If it wasn't for the worm gear being incorrectly installed (the screw facing down preventing the assembly from laying flat and snugging down on the top posts) I could have done it in 15 minutes.
It's a first class product but a word of warning. I upgraded from the 02 LS6 lid and K&N filter and have not noticed any performance gains. Now junking the OEM setup in favor of the B/W will yield some SOTP improvements. Guess I used up all my SOTP improvements when I installed the LS6 lid.
I went this route as Exit28 had a great deal, I already had a hood seal so I sold mine. Then I sold my LS6 lid/K&N filter for $75 so my out of pocket came to $110. Since I'm searching for 320 RWHP I may not actually feel any GREAT improvement installing the B/W but I may have picked up a few more ponies towards my goal of 320 HP.
My LS6 set up yielded 8 RWHP gain on a dyno and that was without benefit of a PCM re-learn, I dyno'd got a base line of 285 RWHP, pulled the OEM lid installed the LS6 lid/K&N filter and re-dyno'd at 293 RWHP. So like I said I may have already tapped into any FREE HP before installing the B/W.
Tom
USAF Retired
[Modified by AFVETTE, 6:57 AM 5/26/2002]
Old May 26, 2002 | 11:41 AM
Fast Mover's Avatar
Fast Mover
Default Re: blackwing to easy (AFVETTE)
I am noticing a significant improvement in power with my Blackwing. Could be due to the Stingers also, B.W.'s are especially good for 00's and older because of the SUPER restrictive airbox. I can't believe I waited so long to remove my stock airbox! :smash:
Old May 26, 2002 | 12:12 PM
GaryZ06's Avatar
GaryZ06
Default Re: blackwing to easy (BRADS C5)
Brad now it is dyno time on a DynoJet.
Old May 26, 2002 | 12:24 PM
Fast Mover's Avatar
Fast Mover
Default Re: blackwing to easy (GaryZ06)
Yeah, but first I need to use the same Dyno as before so I can get accurate gains.
Old May 26, 2002 | 01:05 PM
figment's Avatar
figment
be prepared to be possibly diappointed...unless you want to re-program things $$. I was running way too rich after the install. (dyno'ed ~500 miles after install)
Glad I kept the stock unit, it will be going back on...
Hope your experience is different:thumbup:
[Modified by figment, 11:08 AM 5/26/2002]
To blackwing to easy
Old May 26, 2002 | 01:44 PM
Fast Mover's Avatar
Fast Mover
Default Re: blackwing to easy (figment)
Your Stock 02 Z06 dynos good at approx. 360hp(Already a good breather) My Stock 00 LS1 at approx. 305hp(poor breather) will net a good gain. :yesnod:
Old May 27, 2002 | 12:52 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Bill
Put the Blackwing in the vicinity of the mounting posts. Then walk around the front of the car and reach down between the hood and the front end fascia. Feel for the posts and grommets , line them up and pull the Blackwing towards the front of the car - holding on at the bottom (grommet area) of the unit. Works for me-darn near gave myself a hernia trying to push it on from under the hood !
Old May 27, 2002 | 01:16 AM
RHILL's Avatar
RHILL
Default Re: blackwing to easy (pewter99)
Bill...yeah, do what I do...bend waaaaaay over to the point where you pull a muscle in your leg then you can reach.... :lol: :lol: ..no easy way that I know of
:lol: :lol: :lol: :lol: :D :cheers: this is what I did also.. the only tip I know is have someone else do it :smash: :crazy: :jester
