Need some code help RTD C1780 & PCM P0410
Old May 25, 2002 | 08:24 PM
vette-lee's Avatar
vette-lee
Default Need some code help RTD C1780 & PCM P0410
Anyone know what these codes mean??? Thanks in advance.
chris
Old May 25, 2002 | 09:15 PM
C5Cemo's Avatar
C5Cemo
Default Re: Need some code help RTD C1780 & PCM P0410 (vette-lee)
C1780 is loss of steering position signal.
P0410 is the air pump system not functioning properly. You should check the fuse...hopefully it's to blame.
If you don't have it already, you can download the full list of DTC codes:
http://www.cemozone.com/shared/c5/dtc_codes.doc
This file will help you in the future.
Hope this helps
Old May 26, 2002 | 08:47 AM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: Need some code help RTD C1780 & PCM P0410 (C5Cemo)
Hi there,
Your answer is on the other site, where you posted. I answered your question there.
Besttoyou, c4c5 :crazy:
Old May 26, 2002 | 04:50 PM
vette-lee's Avatar
vette-lee
Default Re: Need some code help RTD C1780 & PCM P0410 (c4c5specialist)
Thanks C5cemo for the code list. Thanks c4c5 for constantly patroling both forums!!
chris :chevy
To Need some code help RTD C1780 & PCM P0410
