Yesterday doing 80 on the highway, A/C on, with outside temp at 90. Digital water temp 212 and oil temp 243! I have flushed the radiator...50/50 distilled water and dexcool..blown out the fins on the radiator too. Oil still is running 20 to 30 degrees over water temp. even around town on the streets. What else can I do? I am going to go to the big corvette Spearfish event in a couple of weeks and weather could be close to 100. It is apox an 1800 mile round trip deal. In the hills of South Dakota who knows what oil temps are going to be at this point.
I am running mobil 1 and basically stock except for a varam air bridge, z06 cover on the air cleaner box, k&n filter and titanium exhaust. Recent tune up.I also put a trans cooler on it to lower the temp in the trans and by passed the stock one, so no heat is being generated by the stock cooler in the radiator either. I am going to dump some water wetter in it today....what else do you think I should do? frustrating!!!!
I really don't want to add another cooler for oil in front of the radiator if I dont have to.
I would just make sure the AC condenser is also clean and unobstructed, check that the fans are running when the AC is switched on (more of a concern on low speeds) coolant and oil are up to proper levels.
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Those temps are fine, but if you wanted to run a little cooler you could put a 180* thermostat in. Stock is 187*. Your cruising temps will be a little cooler but your in traffic temp won't change unless you have the fan on/off temps changed by a tuner or you could use one of our CoolIts to turn your fan on when ever you want to, like when your in traffic. It will also help keep you automatic transmission fluid running cooler.
__________________ Don't forget to check out our products at www.saccitycorvette.com If you like our products, tell others! If not, tell us!
I don't see much over about 195* on the highway. It only varies a bit with the abient air temps.
Did you clean both the radiator and the condensor fins? You almost must have a 90 degree air wand to reach between them and blow them out.
Did you burp the cooling system properly after re-filling? Sometimes, the easiest way is to loosen the front crossover tube between heads and let the air out there.
When pulling off the track or for the last slow mile home (A/C off) in hot weather it would go to 220 where the first fan comes up, sometimes 230 in hot weather off the track
I added a Sac City Cool It so I can manually call up high right fan off the track or for that last mile. Keeps it at 200.
108* yesterday, with the A/C OFF I was seeing 225-230* water temps in stop & go traffic and 212* on the highway.
I removed my radiator shroud this morning. So I'm going to see if my stop & go temps are reduced.
Removing your radiator fan shroud will INCREASE your temps in stop and go traffic. The purpose of that shroud is to direct the air from the fans through the radiator. Not having the shroud won't make any difference at speed but sitting it traffic it almost definitely will unless you have a significantly larger than stock fan setup.
You and the OP should clean the debris out of your radiator and A/C condenser and add some watter wetter to your coolant if you want to lower your temps a little. That said, neither of you are reporting temps that are out of acceptable range. Especially if it's 108 degrees outside.
This is info from Oldvetter here on the forum.
After reading it you'll see your temps are normal for a stock C5.
C5 Cooling Fans Operation
"The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph). "
You're not going to fix this unless you change the setpoints for the fans.
But, what is the point of reducing temps, if it was factory made to run so high?
my system has a 50/50 mix with new water pump, new coolant reservoir & new 15 psi cap, running with the CoolIt, system blurped properly, released air at air bridge also,, - got once to a big hill, alot of corners, 90 degree outside.. 1st gear and 2th all the the time, once got on top display was reading 238, stoped by side and it needed 1 minute to start droping.. if i'd shut off car i'm pretty sure it would explode something underhood and let the water out.
We have this issue all the time here in Arizona ..... I put together a cleaning tube to clear debris from both the radiator and the condense with only removing the upper bridge making the space between the rad and condenser accessable .... 20 miniutes of cleaning a couple of times a year keeps our C5s running cooler all year round .....
These are available ... so just drop me a PM and I'll shoot one off to ya ......
Ive always been curious about this. Expert tuners in the C3 forum swear that around 72 GM started making their cars to run hotter for emissions reasons. That is why on the old SBCs and BBCs the first power increase is to advance the timing so it lowers the cylinder temps.
I see.
For you guys who cleaned the radiator: is there any possibility to clean it with removing the shroud and radiator still let in the car? I really would not like to remove whole radiator
