Fob Problem?
Old Jun 27, 2012 | 09:50 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Fob Problem?
My fobs (both) when I got my 98 were not working. After reading some info here in the search on synching them, I stood outside the car today and pushed the unlock/lock buttons at the same time. The car horn beeped. Now every time I get close to the car with the fob that I got working, the car does one short beep until I get out of range. Did I do something wrong or do I need to resynch this fob another way?
Old Jun 27, 2012 | 10:04 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
No they are passive and will drive you nuts around the car/ you did the wright set up.
Old Jun 27, 2012 | 10:08 PM
lucky131969's Avatar
lucky131969
There is a switch for passsive mode on the FOB....see what position it's in.
Old Jun 28, 2012 | 07:56 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Also, my '99 has the passive switch as well. I discovered that simple pocket dust getting through the switch slider, will turn on the passive function even though the switch is off. Blow it out and slide it on and off a couple of times, usually worked for me.
Old Jun 28, 2012 | 03:26 PM
DA1984VETTE
As your looking at the fob, the little ****? is all the way to the left and it says off.
Old Jun 28, 2012 | 07:16 PM
65GGvert's Avatar
65GGvert
As previous poster said, sometimes it isn't off when it should be. Slide the switch quickly back and forth several times and see if that helps your honking. (leave it "off" after you slide it)
Old Jun 28, 2012 | 07:47 PM
DA1984VETTE
Will try that and thanks for the suggestions.
To Fob Problem?
